Thread: Intense's S3 Heads VS. ZZP's S3 Heads.
Results 1 to 20 of 33
  1. #1 Intense's S3 Heads VS. ZZP's S3 Heads.
    GT Level Member pontiackid's Avatar
    KCMO
    Lets talk head porting.
    Intense------------------------------------------------------Both--------------------------------------------------------ZZPerformance
    Milled .005" for flatness-------------------------------Setup to run the same lift (.600)----------------------------------Typically milled .005" (add. milling avaliable upon request)
    $2000.00-----------------------------------------------#130lbs Comp Cam Springs--------------------------------------------------$1500.00
    Anyone have personal experience or any numbers comapring the 2 sets? Dyno's with same/similar setup but, the heads?
    I seem to recall reading that on on of ZZP's cars they even changed to Intense's design and saw a gain...
    Valve Sizes?
  2. #2 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    you can get much more extreme heads from an engine shop for under $1000.
  3. #3 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    X2...Kyle go visit Kevin's Machine Shop across the street from Cody's right off the square, or RAD Performance in Gladstone.
  4. #4 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    and by much more extreme i mean theyll be like "stage 5" from a vendor. they dont even sell heads that good.
  5. #5 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    Charles City, IA
    Yeah i spent $450 for mine to be milled, ported, valves ground and seated and for some new seals.
    SMGPFC Two Nipple General
  6. #6 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    KCMO
    I know I could go to a machineshop. What I don't know is things like appropriate valve sizes and stuff and figure where the leading companies are setting.
  7. #7 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    Charles City, IA
    Get some heads from an 04+ they have to bigger valves. Or you could just get the valves and have your heads machined from them. I believe trannyman uses the valves from the 04+'s.
  8. #8 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    Yup, '04+ valves = BIGGER
  9. #9 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    start with 04+ heads with the bigger intake valves. then take them and get them nicely ported, polished, decked, etc. with stock valve sizes and then make sure the valve guides are cut down and what not to run the lift you want. i would buy a big cam right away if youre going to do this (IS3 or just get a custom from PRJ). go big or go home.
  10. #10 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    I was wondering kinda the same time thing as pontiackid. Is there a place u could send heads to have that stuff done for that cheap cause up here in rapid city, south dakota there are no machine shops here that will do the work. I dont understand all that lift and stuff that u guys talk about. I dont wanna spend 1500 to 2000 bucks for heads at all especially if u can get heads done to like a "stage 5" head work as bio calls it lol. I wanna go with a big ass cam but dont know what to choose, which kinda rockers to get and all the stuff to the heads.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  11. #11 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    With a big cam, rockers are iffy...just stick with 1.60:1 Roller Rockers so it is easier on the valves. Kinda like the old saying goes...one or the other...cam or rockers.
  12. #12 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    oh i didnt know that u shouldnt run rockers with a cam. Is there anybody on here that does good head work so i dont have to spend a **** load of money on ZZP heads when i go there next month. I have a body that is in love with ZZP and is getting alot done to his car on his turbo'ed monte so i figured i would have them put a cam in, smaller pulley, injectors, tune, and valvetrain work since im not familiar with that kinda of stuff. What kinda of cam should i run? i was thinkin bout the XP but figure i should get some opinions. like u said blue, "go big, or go home" so thats what ima do but i just need some help on deciding what to do. Sorry pontiackid, not tryin to jack your thread. just figured might as well bring it up since its the same topic and not starting another thread.
  13. #13 Re: Intense's S3 Heads VS. ZZP's S2 Heads.
    chicago
    triple edge performance
  14. #14 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    KCMO
    Well Bio, I took your word and got ahold of some L32 Heads from Morad. We will see. What do you mean by stage 5? I mean I know what you mean but, I asked about stage 3's as that seems to be the line where bigger it is reccomended that you run race fuel...I would like to be able to fill up at the pump still.
  15. #15 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    Charles City, IA
    Unless you put some 10:1 pistons in you can still run 91/93 just. How much did you spend on the heads from morad?
  16. #16 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    KCMO
    $240 to my door.
  17. #17 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    Charles City, IA
    Not bad... I will have to look into some when my engine goes south. I hope that is not for a while tho.
  18. #18 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    just take them in and ask what they can do with them for what price. you can usually get a good ported set that is clearanced for about $800.
  19. #19 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    Charles City, IA
    I got what they called a street set up with a mild port and valve job with decking done for $450. I did not have the guides clearanced tho.
  20. #20 Re: Intense's S3 Heads VS. ZZP's S3 Heads.
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    damn, i would pay $450 for a port job if I could find it that cheap. I already have to have my heads magnafluxed and rebuilt...
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  1. L67 heads
    By DLAVENGER in forum General Tech Discussion
    Last Post: 06-24-2009, 07:03 AM
  2. L36 Heads
    By Abrasive in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2008, 09:02 AM
  3. heads for a gt
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2008, 11:21 PM
