Thread: Rough Idle
Results 1 to 13 of 13
  1. #1 Rough Idle
    Banned
    Texas
    I have a 1998 GTP on a cold start it idle just right until it warms up then the rpms jump up and down maybe 200rpms i have checked for vacuum leaks. And there is none so what else could it be? It has a N* on it with a ported blower and a FWI. It has been doing this before I ever put mods on it.
  2. #2 Re: Rough Idle
    Saraland Alabama
    there are a few things that can cause that, a bad plug or wire, a failing coil, failing module, internal engine wear (blowby, and the like) without testing ever single component it will be tough to narrow down
  3. #3 Re: Rough Idle
    Banned
    Texas
    I have changed the wires and plugs
  4. #4 Re: Rough Idle
    Saraland Alabama
    have you done a seafoam treatment? Won't hurt (if done properly)
  5. #5 Re: Rough Idle
    Banned
    Texas
    no I haven't but I am about to put a s1x in it.
  6. #6 Re: Rough Idle
    Hoffman/Schaumburg, IL
    No offense, but find the prob first, cause If you add the cam and it gets worse or causes something else to go wrong, you may be further up a creek than when you started
    ~end rant
    Edit, do you have a tuned pcm, it may be required for the mods you have already
  7. #7 Re: Rough Idle
    Banned
    Texas
    I dont have a tuned PCM but it was doing it when I bought the car stock.
  8. #8 Re: Rough Idle
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    does your tach act normal?
    also could check the IAC on the TB. (clean w along with the rest of the TB)
  9. #9 Re: Rough Idle
    Fort Wayne, IN
    Quote Originally Posted by Toasty View Post
    That would be my guess.
    U-bend/ResDelete// 3.4"// MSD 8.5mm// TR6s// ZZP 1.0 PCM// 72mm TB w/ TB spacer// WizAired CAI// 180° tstat
    Best ET (stock): 14.689
    Best Trap (also stock): 93.82
  10. #10 Re: Rough Idle
    Banned
    Texas
    no my tach arm moves up and down under 1000rpms
  11. #11 Re: Rough Idle
    Banned
    Texas
    the IAC is new on a N*
  12. #12 Re: Rough Idle
    SW Chicago Suburbs
    Quote Originally Posted by Red_GTP View Post
    but the tach movement matches the rpms, right?
  13. #13 Re: Rough Idle
    Banned
    Texas
    yea I wish I could take a video.
  1. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
