Thread: Wizaired intake tubing alternative?
Results 1 to 5 of 5
  1. #1 Wizaired intake tubing alternative?
    Fort Wayne, IN
    I'm looking for a more rigid alternative to the intake tubing that comes with the wizair. I've got some ideas, but thought maybe someone has done it already and had specifics.
  2. #2 Re: Wizaired intake tubing alternative?
    Jersey
    The wizard tube already thought of that, the tube is already insulated repelling as much heat as it can.
    16' wrx sti- stock
  3. #3 Re: Wizaired intake tubing alternative?
    Fort Wayne, IN
    RIGID not frigid...as in non-flexible. Insulation has nothing to do with how sturdy the tubing is.
  4. #4 Re: Wizaired intake tubing alternative?
    Wausau, WI
    PVC..........heat it up enough to bend it to the proper angles?
  5. #5 Re: Wizaired intake tubing alternative?
    Jersey
    Quote Originally Posted by xxmattfxx View Post
    ah ok, I didn't see that part.
    16' wrx sti- stock
  1. as good as wizaired intake #2!
    Last Post: 02-19-2009, 01:01 AM
  2. headlight alternative
    By 99gpse in forum Visual/Body Modifications
    Last Post: 12-11-2008, 09:59 AM
  3. Wizaired Cold Air Intake for 05 GTP?????
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 03:41 PM
