so i was just curious if the stock injectors off an LS1 would work if swapped onto the L67 platform?...
IIRC, I think they flow less so it would be a downgrade.
If your going to swap in anything, at least get 42.5#. Whatever you do though, the PCM will need to be tuned for the different injectors. Otherwise your car will either run pig rich or won't run at all because of being too rich.
Looking at your mod list you DON'T need injectors right now, it won't do anything for you...
LS1= #28lb
LT1= #24lb
GTP = boosted so #33lb stock...
Get Ford Lightning or '03/'04 Cobra injectors...but FYI, your no where near needing them for your GTP.
i am in need cause one of mine is shot...and i was just trying to figure out a cheap way to remedy it...since im hella broke at this time...
you have to swap them out as a set if you are going to do so. If you need one, just find one from a junkyard, ed morad, etc.... or just buy one new if you can afford it.
What? Where'd you get this? If one injector is bad and you know which one it is then you trash the crap one and put in a different one. Riceburner...I am upgrading to #42.5lb. injectors here soon and you can buy my whole injector set from me and I'll throw in new O-Rings for $50 + shipping if you want to do that...shoot me a PM if you want.
so one more ?...would any 3800 coil pack work for the gtp?
they are different part numbers, so they should be different....from the NA to the GTP that is. Atleast, that is what I have read. I never actually have swapped them out to see.
hum cause i have a misfire on #4 and swapped the "problem" injector but code did not follow....leading me to think its the coil...
can you get a coil pack from a junkyard to swap out?
