Thread: attempting coolant flush
Results 1 to 2 of 2
  1. #1 attempting coolant flush
    rhode island
    hey guys i have read a few threads on this so im fairly confident i cal pull it off. just bought a 97 gtp supercharged, and noticed it has dex-cool which has alot of goopy residue in it. i will be switching to peak G05 as soon as i get it flushed out.
    i will be attempting a thourough coolant flush, i bought the kit, the prestone coolant cleaner and have a hose ready to use.
    what im wondering is,
    A. where is the best place to put the T. i have heard putting it on the heater hoses works well to flush the block. the heater has 2 hoses an in and an out i assume (lol) does it matter where i put the fresh water hose or as long as its in an elevated position its ok.
    b. i will be opening the radiator hose at the bottom , and i have read here that i should also open the knock sensors to get a thourough block flush. anyone have a description of where this/what to look for as i cant find any mention of it in the manual.
    c. when i first drain the dex cool and start pumping clean water through, should i start with the engine off and turn it on a bit to clear the water pump, havnt seen anything on this.
    thats all really, not sure if i want to start this operation untill i have a better grasp of these 3 things. any help is greatly appreciated.
  2. #2 Re: attempting coolant flush
    May 2008
    McHenry IL
    its simple as changing plugs ull do fine get her done =]
  1. Coolant Flush, is this the "inlet"
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:58 PM
  2. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  3. Coolant System Flush
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 08:59 PM
  4. Going to vip for a coolant flush
    Last Post: 03-12-2008, 03:42 AM
  5. Coolant Flush : How to?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-09-2008, 08:35 AM
