Thread: Shows boost only in reverse
Results 1 to 12 of 12
  1. #1 Shows boost only in reverse
    SE Level Member gtp59's Avatar
    La Crosse, WI
    For some reason my car is only showing boost when my car is in reverse. Obviously i have a major leak but cant find it. The only thing i could think of is a hose coming out right under my supercharger snout that is open. Does anyone know where that is suppose to go. Thanks in advance.
  2. #2 Re: Shows boost only in reverse
    Yeah. It goes back UNDER it. Look for the "T" Fittings. Most likely it is rotted and you'll have to get a new set, which you can get for less than $30 from a local dealership...should be called the EVAP Vacuum Line System or something like that.
  3. #3 Re: Shows boost only in reverse
    you have disconnected vacuum lines and you wonder why youre seeing no boost? how does that thing idle? like junk i bet.
  4. #4 Re: Shows boost only in reverse
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    they broke mine when did the recall smh and didnt bother fixing it, so i left skid marks after i picked the car up after i paid for that line. if its not cracked just replace the t with some from autozone they have some that match up almost exactly to oem specs
  5. #5 Re: Shows boost only in reverse
    Quote Originally Posted by silvermistchick View Post
    The autozone T-Fittings suck epic balls.
    Just go to the dealership and do it right the first time (meaning BUY the part FROM them, dont have them touch it) that way it won't rot on you again...or at least it wont for like 10 years or something
  6. #6 Re: Shows boost only in reverse
    Wausau, WI
    and what exactly are "epic" balls?
  7. #7 Re: Shows boost only in reverse
    Barksdale AFB, LA
    The whole vacuum harness is cheap. Grab it from the dealer and have no worries.
    2009 Subaru Impreza WRX STI
  8. #8 Re: Shows boost only in reverse
    Bastard Reptile's Avatar
    Kansas City, MO
    ^^ Yup, GM number is 24508742
    If you pay over $22 then you're getting ripped off....but it is a whole new line from the BBV solenoid all the way back to the MAP sensor.
    Install and enjoy.
  9. #9 Re: Shows boost only in reverse
    in a house
    Wow, finally a part number. My Gm dealer in town searched for 15 mins and could not find anything. Thanks for posting..
  10. #10 Re: Shows boost only in reverse
    Kansas City, MO
    <-----Awesome....that's why.
  11. #11 Re: Shows boost only in reverse
  12. #12 Re: Shows boost only in reverse
    Kansas City, MO
    Dammit....I'm used to Instant Messages....
    So much for my Ninja Edit.
  1. 4T65E--No Reverse!!!
    By Luminary in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2011, 01:51 PM
  2. Reverse lights
    By KR1ST1N_X3 in forum Visual/Body Modifications
    Last Post: 04-15-2009, 08:10 PM
  3. reverse
    By gotboost3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2009, 11:23 AM
  4. what TV shows?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 03-23-2008, 10:10 AM
  5. DIC Shows Incorrect Day of the Week
    By wrngway in forum General Tech Discussion
    Last Post: 01-30-2008, 07:39 PM
