Thread: Knock Retard when accelerating
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Knock Retard when accelerating
    Fort Wayne, IN
    I've been trying to trace down the cause for a while now, and it wouldn't be that big of a deal if I weren't getting at least 1.9* of KR whenever accelerating. At Idle, if I give it gas I will get a vibration in the 1100-1200 RPM range and the scanner will occasionally show some misfires mostly in cylinder 4. I've changed the plugs, wires, fuel injectors, and sprayed for vacuum leaks without any success. I am running a stock pulley, and have no engine codes.
  2. #2 Re: Knock Retard when accelerating
  3. #3 Re: Knock Retard when accelerating
    Coil Packs...I bet there or the ICM...
    Hope you find it...as for the KR. Could be false too. Check your motor mounts...I've seen some that have collapsed and caused things to make contact (I.E. DP & Sway Bar) and cause false knock.
  4. #4 Re: Knock Retard when accelerating
    Fort Wayne, IN
    Mostly Stock...CAI, U-bend, delete, AP605 Spark plugs, aftermarket mufflers, and DHP v1.0 PCM
  5. #5 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Need to post up a scan or something more. I wouldn't be too worried about 2*Kr on stock engine/pulley though...
  6. #6 Re: Knock Retard when accelerating
    Fort Wayne, IN
    1.9* of KR is during normal driving/acceleration, it can get up to 5.6* at WOT. I scanned with EFI Live which uses it's own propriatary format. But here is s snippet, one at idle...one at a brief WOT run.
    IDLE
    RPM:734
    o2 #1: .807v
    o2 #2: .009v
    SPARK Deg: 27
    KR: 0
    INJDC1: 4.777
    INJDC2: 4.777
    AFR: .5
    MAF: .98 lbs/min
    ECT: 196
    IAT: 154
    LONGFT1: -2.3
    LONGFT2: -98.4
    WOT
    RPM: 4585
    o2 #1: .924
    o2 #2: .017
    SPARK Deg: 7.0
    KR Deg: 5.6
    INJDC1: 59.705
    INJDC2: 59.705
    AFR: 1.00
    MAF: 21.91 Lbs/Min
    ECT: 196
    IAT: 147
    LONGFT1: -0.8
    LONGFT2: -96.9
  7. #7 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I'm personally leaning towards bad o2 sensor, or maybe even a bad cat.
  8. #8 Re: Knock Retard when accelerating
    riverside
    lol......................
  9. #9 Re: Knock Retard when accelerating
    Wausau, WI
    Quote Originally Posted by jerseymike68 View Post
    at what?
  10. #10 Re: Knock Retard when accelerating
    Fort Wayne, IN
    Scan
    72909WOT from xxmattfxx -- Scan Depot dot net
    ...sorry it's all over the place
  11. #11 Re: Knock Retard when accelerating
    Fort Wayne, IN
    ttt
  12. #12 Re: Knock Retard when accelerating
    Fort Wayne, IN
    Haven't made a whole lot of progress on this issue but I have done quite a few more tests.
    -Injectors Replaced (was an occasional few misfires at idle)
    -Upper Radiator supports replaced (rubber had cracks in them, suspected false knock)
    -Spark Plugs and Wires Replaced (again, misfires at idle)
    -LTFTs close to zero
    -230 degrees at the inlet and outlet of the catalytic converter. (no other indication of a bad cat...smell, glowing, lack of exhaust)
    -Fuel Pressure within spec. (idle spec)
    -No Trouble codes
    -Front O2 sensor replaced
    I'm not quite sure where this KR is coming from, I have stock pulley and all other performance related mods are more, restriction reducers...Cold air intake, U-Bend Delete, Magnaflow mufflers.
    What I am seeing now seems to vary with the weather and the temp of the engine. Taking a simple drive to work, or a friend's house I'll look down at the max KR and see something near 5 degrees. On the highway in higher speeds, I'll see KR fluttering around a consistent 1-2 degrees even with cruise control on.
    There are other things that are possible culprits that I could throw money at, but I'd rather have some guidance based on my conditions and save a couple bucks.
  13. #13 Re: Knock Retard when accelerating
    Donating Users kfish's Avatar
    Ohio
    are you running premium? haha
  14. #14 Re: Knock Retard when accelerating
    Fort Wayne, IN
    always have
  15. #15 Re: Knock Retard when accelerating
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    sorry to thread jack here but how did you get the EFI live scanner to work? my buddy has one and we tried to use it. no pcm selection would let us scan my gtp.. which one did you select to get it to work?
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  16. #16 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I chose "Gen III LS1 99-08 PCM", but if I recall I've used others without much trouble, haven't done anything special...it just works.
  17. #17 Re: Knock Retard when accelerating
    Spearfish, sd
    cool.. i'll have to borrow it from him again and try again..
  18. #18 Re: Knock Retard when accelerating
    Jan 2009
    Tallahassee, FL
    Check out the coils, they could send out a weak spark. Do you ever get a misfire while accelerating? What are your plugs gaped at?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  19. #19 Re: Knock Retard when accelerating
    ^^that is what I was gonna say...or it is false knock. Check the motor mounts and sway bar in the front...might be broken or the mounts might be shot.
  20. #20 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Im trying to read the scan but I think EFI is giving some inaccurate readings for everything, the kr, rpm's, ect, iat and ltfts look about right, but everything else is innacurate. It is very well possible that you just need a tune and richen the car up a bit and remove some torque management.
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  3. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  4. Weird Whine When Accelerating
    By angelamarie990 in forum General Tech Discussion
    Last Post: 04-08-2009, 10:30 PM
  5. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
