Thread: How TO REMOVE OIL PAN??
Results 1 to 12 of 12
  1. #1 How TO REMOVE OIL PAN??
    May 2008
    McHenry IL
    i saw a previous thread but it didnt help me.... ok well i got only 4 bolts left holding the pan on and the motor mount is in the way FF how can i get em out without messing with the mount yet?? GRRRR
  2. #2 Re: How TO REMOVE OIL PAN??
    Ohio
    check the other post i just replied to it
    00 GTP demodded and forsale
  3. #3 Re: How TO REMOVE OIL PAN??
    why are you removing the oil pan? you cant possibly think that you can just fix everything from the bottom up, do you?
    take the whole damn motor out.
  4. #4 Re: How TO REMOVE OIL PAN??
    Took the words right off of my keyboard.
  5. #5 Re: How TO REMOVE OIL PAN??
    Jersey
    pull the motor.
    16' wrx sti- stock
  6. #6 Re: How TO REMOVE OIL PAN??
    Ohio
    pull the motor makes the work alot easier but it can be done without pulling it. this past time i was forced to do all work in frame an now they r listening to me and letting me pull it since it still ahs a prob after all the inframe work that i had to do.
  7. #7 Re: How TO REMOVE OIL PAN??
    Ohio
    pull the motor will be the easy way an if u have the tooling to go that route an people that wont force u not to do that then pull it for sure!
  8. #8 Re: How TO REMOVE OIL PAN??
    Charles City, IA
    Just pull it.
    SMGPFC Two Nipple General
  9. #9 Re: How TO REMOVE OIL PAN??
    Charles City, IA
    Read your other post, if you can't spin it at all you need to pull the engine.
  10. #10 Re: How TO REMOVE OIL PAN??
    May 2008
    McHenry IL
    well guys we didnt pull anything and got her done in about a hour were god speed lol
  11. #11 Re: How TO REMOVE OIL PAN??
    SE Level Member Talsition's Avatar
    Stevens Point, WI
    Funny I was going to come on here and ask the same question today, leaking all kinds of oil from the pan gasket. Had it up on the lift and thought I might be able to drop it with out pulling the motor, but that sounds like an easier way to go.
    98 Grand Prix GTP - Custom FWI, 104 autolites, 180* t-stat, TDR Fbody Break Kit
    95 Eagle Talon ESI - 2Gb Conversion, lots of mods still slow.
  12. #12 Re: How TO REMOVE OIL PAN??
    May 2008
    McHenry IL
    we didnt pull it just used some wood after we took the rear engine mount out man some wood to hold the engine up worked great =p
  1. How to remove oil pan
    By CheeseWithMyWHINEplz in forum General Tech Discussion
    Last Post: 07-01-2009, 01:54 PM
  2. Remove cat.
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 02:43 PM
  3. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
  4. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
