Thread: T-Fitting for my vacuum line & boost gauge.
Results 1 to 16 of 16
  1. #1 T-Fitting for my vacuum line & boost gauge.
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I have been attempting to locate a rubber t fitting for the vacuum line. I need one to replace the cracked one on the passenger side just under the S/C snout and another to run a boost gauge (behind the blower near the map sensor.)
    Does anyone know where i can find this rubber t fitting? Or better yet if i can get them from GM is there a GM part number?
    I have found plastic ones in the Autoparts stores but they were either too big or too small. The closest one fit the hose but the lip, like 1/8 of an inch down on the hose, did not fit thus making the fitting too small.
    Any help is appreciated!
    2006 Grand Prix GXP
  2. #2 Re: T-Fitting for my vacuum line & boost gauge.
    Buy the entire new set from GM. Only thing I recommend as your not halfassing it with autozone special t-fittings. IIRC they are about $25 or so.
  3. #3 Re: T-Fitting for my vacuum line & boost gauge.
    Houston, TX for now
    W-body store also sells the fitting and tube in a kit. They offer it in a few colors.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  4. #4 Re: T-Fitting for my vacuum line & boost gauge.
    Jul 2008
    New York
    Thanks!
    Quote Originally Posted by LOUDANDPROUDGTP View Post
    Thanks, believe it or not i have never been on that site before. Unfortunately i don't think they sell these t-fittings any more on there, or at least i couldn't find them.
    2006 Grand Prix GXP
  5. #5 Re: T-Fitting for my vacuum line & boost gauge.
    Good thing you haven't been on WBS. Most of the time you get what you don't order...but that is just my personal experience.
  6. #6 Re: T-Fitting for my vacuum line & boost gauge.
    Houston, TX for now
    Somtimes WBS is really good to deal with and other times they SUCK! It is all the luck of the draw. The T fittings only come in the vaccum line set from WBS.
  7. #7 Re: T-Fitting for my vacuum line & boost gauge.
    Just do it right and get it from the dealer the first time.
  8. #8 Re: T-Fitting for my vacuum line & boost gauge.
    Ohio
    ^ agreed! Dont bother with w-body store. they cant even package their stuff as to not get damaged or even get it to the post office properly
    00 GTP demodded and forsale
  9. #9 Re: T-Fitting for my vacuum line & boost gauge.
    Jul 2008
    New York
    I was able to buy it in a kit offered by gm. Two t fittings, one L and three vacuum lines. It was $20.
    2006 Grand Prix GXP
  10. #10 Re: T-Fitting for my vacuum line & boost gauge.
    Good deal dude.
  11. #11 Re: T-Fitting for my vacuum line & boost gauge.
    Evansville, IN
    Where did you find that kit at? Is there a part number or a website you can direct me to? I need to replace mine as well. Thanks a lot
  12. #12 Re: T-Fitting for my vacuum line & boost gauge.
    Wausau, WI
    if you have a part number........go to gmpartsdirect.com........they always have better pricing on GM parts, but if you need it fast or if it isn't more than a forty dollar part from GM, then get it at your local dealer. partsdirect will charge I think a minimum of $10 or so for shipping on your first part, so just be aware.
  13. #13 Re: T-Fitting for my vacuum line & boost gauge.
    Evansville, IN
    Quote Originally Posted by Liquifire View Post
    Yeah, that's my problem, I don't have the part number, and there's only one place in my city that even offers Pontiac parts. :/
  14. #14 Re: T-Fitting for my vacuum line & boost gauge.
    Jul 2008
    New York
    Hey i sent you a pm, sorry i just got back from vacation.
    I could not find a place to get them online, i just used my local GM dealer.
    2006 Grand Prix GXP
  15. #15 Re: T-Fitting for my vacuum line & boost gauge.
    in a house
    Quote Originally Posted by DnaProdigy View Post
    Do you have a part # that you could post please? I have been to GM and the parts guy could not locate it.
  16. #16 Re: T-Fitting for my vacuum line & boost gauge.
    Jul 2008
    New York
    I was sent a schematic with a number on it but its only 3 digits and as far as i know not an official GM parts #.
    The number on the schematic is 558 if that is any help.
    2006 Grand Prix GXP
  1. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  2. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
  3. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
  4. What is Vacuum on a boost gauge ??
    Last Post: 04-07-2008, 12:54 PM
