Thread: ZZP FMHE install and pics?
Results 1 to 6 of 6
  1. #1 ZZP FMHE install and pics?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    I need some pics and help on how to install the ZZP Front Mount Heat Exchanger.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: ZZP FMHE install and pics?
    anybody?
  3. #3 Re: ZZP FMHE install and pics?
    Jan 1970
    Maquoketa, Iowa
    Which one?
    Self tapping screws>Bumper support...
  4. #4 Re: ZZP FMHE install and pics?
    The one that they manufacture. I just dont know how to hook the pump up and all and which hoses go where.
  5. #5 Re: ZZP FMHE install and pics?
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by bbptech View Post
    You want the IC pump at a low point, and a way to bleed the system of air.
    This would be your basic setup:
    HEAT EXCHANGER BOTTOM TO> PUMP INLET
    PUMP OUTLET TO> INTERCOOLER CORE INLET
    INTERCOOLER CORE OUTLET TO> HEAT EXCHANGER TOP
    A 5-7psi cap on the highest point in the lines would suffice to bleed the air out and add more water to the system.
  6. #6 Re: ZZP FMHE install and pics?
    Where wuld i go about getting a 5-7 psi cap? and where would that go?
  1. 4T65E Differential INSTALL PICS!!!
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-23-2017, 12:15 AM
  2. FMHE stage 4 install.
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2014, 10:44 PM
  3. Intercooler install pics & help?
    By qball98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:06 AM
  4. Finished Gen V Install Pics
    By Street Wolf in forum General Tech Discussion
    Last Post: 07-20-2008, 07:33 PM
  5. 'Partial' Gen V Install Pics
    Last Post: 07-14-2008, 10:47 PM
