Thread: Intercooler install pics & help?
Results 1 to 11 of 11
  1. #1 Intercooler install pics & help?
    Not on here anymore
    can anyone who has it done show full pics of the ic setup? im trying to decide to run the lines from the pass side straight to pump and res, or run them around the driver side around the back to get more capacity in the lines and i can only find pics here and there not the whole install
    Bottom of RES (exit) - IC pump In - IC Pump out - FMHE bottom (fluid goes up and through?) - FMHE TOP to the IC Core (which side Front or Rear Guessing front) then out the back side to Top Of Res?
    front view of fmhe
    routing of lines
    pump location
    res if you have one
    Thanks
  2. #2 Re: Intercooler install pics & help?
    Moore, Oklahoma
    I donno if I understand what you describe, let me tell you mine....
    From the Bottom of the FMHE line goes to the Pump, line goes to the core, line exits the core and enters my reservior from the top, line exits the bottom of the Reservior and goes to the top of my FMHE....
    Shawn W. Larsen
  3. #3 Re: Intercooler install pics & help?
    Banned - Busted For Scamming
    Feb 2009
    You will be the first new design core most likely, the lines will be going out the drivers side for better fitment, just something to consider.
  4. #4 Re: Intercooler install pics & help?
    Not on here anymore
    OH HAHA Good thing ya told me then i thought they'd be going in the normal spot
    hows that gonna work with the crossover and all? ok?
  5. #5 Re: Intercooler install pics & help?
    TDCRacing
    Guest
    The new design will be a LOT easier as far as the routing of the lines go. You won't be replacing the lines every week from the belt eating them up.
    I'm sending you your tracking number now BTW
  6. #6 Re: Intercooler install pics & help?
    Not on here anymore
    any pics yet? well duh guess not being mines gonna be the first one HAHA guess i gotta take ALOT of pics
  7. #7 Re: Intercooler install pics & help?
    Wausau, WI
    that would be great for the rest of us who could use this in the future and curious what it looks like and involves
  8. #8 Re: Intercooler install pics & help?
    Moore, Oklahoma
    Quote Originally Posted by TDCRacing View Post
    Good idea with routing the lines on the opposite side, I've thought for years someone should simply turn the inner core around, glad someone finally did it. I've thought the routing the hoses through the belts has always been a dumb idea IMO. One of the many reasons I never went with the ZZP style core.
    BTW, the hoses above the crossover won't hurt a thing. My inlet line on my IC enters above the crossover. The heat from it doesn't affect it whatsoever. In fact on a 100 degree day or any day for that matter you can touch the metal barb (which the hose is attached too) and its cool or cold to the touch in a hot engine bay.
    BTW, i'm in for pics of this core uninstalled and installed. If my inner core ever fails (which I hope it never does because its a welded in core), i'll definately buy one of these. Hopefully you'll still be around if that ever happens. I expect to get many years out of mine.....
    Shawn W. Larsen
  9. #9 Re: Intercooler install pics & help?
    Moore, Oklahoma
    Quote Originally Posted by qball98 View Post
    If you plan on running that same reservior I recommended to you I have a good idea on how to route you intercooler hoses, if your interested in hearing my idea anyway. PM if so....
    Shawn W. Larsen
  10. #10 Re: Intercooler install pics & help?
    Not on here anymore
    If im the first with this design ill def be taking LOTS of pics if someones willing to help me post them!
    ill pm you now man
  11. #11 Re: Intercooler install pics & help?
    Dec 2008
    Canada
    ill pm you now man
    I can show you how to post them because I am also going with their full size I/C.
  1. ZZP SS Intercooler pics needed
    By FuglyGTP in forum General Tech Discussion
    Last Post: 05-22-2009, 04:38 PM
  2. Full Size Intercooler Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:38 AM
  3. How to install stage three intercooler?????
    By GINOSGTP in forum General Tech Discussion
    Last Post: 02-25-2009, 07:52 PM
  4. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
  5. Handful of Questions for an Intercooler Install
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2008, 07:27 AM
