Thread: Sun roof gasket leaks
Results 1 to 5 of 5
  1. #1 Sun roof gasket leaks
    Donating Users GrandpaAl's Avatar
    Salt Lake Utah
    Evening guys! Besides the dealer, where do we go for the gasket that the sunroof seals to. I found mine leaking after running it through the carwash today. After 93k the little ridges the glas seals to are flat.
  2. #2 Re: Sun roof gasket leaks
    Jersey
    i got mine from the gm dealer, $150.00. Make sure your sunroof glass itself is adjusted properly, and the drain tubes are cleared out.
    btw i have a thread on my sunroof problems if your interested. It's in the grand prix section at the bottom.
    16' wrx sti- stock
  3. #3 Re: Sun roof gasket leaks
    Wausau, WI
    ......and why is this in the motor section? Junkyard would be an alternative to dealer but obviously it is used. You could also go to a dealer, get the part number and get it much cheaper at gmpartsdirect.com.................Ed Morad might have a used one as well....
  4. #4 Re: Sun roof gasket leaks
    Salt Lake Utah
    Very good, I'll check out thread before going to the dealer. My Helm service manual arrived today, check that too. Thanks.
  5. #5 Re: Sun roof gasket leaks
    Salt Lake Utah
    Motor section huh... I'm a little clumsy navigating this site still.
  1. How to Trace Vaccum leaks for P0171 [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2012, 09:52 PM
  2. 04 GP leaks water thru map lights.
    By schreurs1 in forum General Tech Discussion
    Last Post: 05-22-2009, 12:07 AM
  3. leaks...
    Last Post: 04-21-2009, 10:20 PM
  4. Common oil leaks and fixes?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2008, 07:56 PM
  5. Coolant leaks
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 10:13 PM
