Thread: I truly am totally nuts.
Results 1 to 20 of 24
  1. #1 I truly am totally nuts.
  2. #2 Re: I truly am totally nuts.
    Oklahoma
    I have two questions for ya. How and why?
  3. #3 Re: I truly am totally nuts.
    SE Level Member Incomudrox's Avatar
    New Holland, PA
    Ever play with the rotors and get your finger caught in them? Sucks. I got my finger bitten by those gears hurt a little bit LOL.
  4. #4 Re: I truly am totally nuts.
    Quote Originally Posted by Incomudrox View Post
    Yes, I nearly chopped my finger off. I was running them with an electric drill at the time too. I probably should have got stitches.
  5. #5 Re: I truly am totally nuts.
    3 jaw puller, took about 10 minutes.
    Remeber my dry film lubrication thread? That's why.
  6. #6 Re: I truly am totally nuts.
    Oklahoma
    Ohhhhh yeah. Nice thinking Ron. Any progress on that?
  7. #7 Re: I truly am totally nuts.
    Oklahoma
    Hey, now looking at your picture more, is that just a bushing in the plate or is that a roller bearing there?
  8. #8 Re: I truly am totally nuts.
    Roller bearing. Looks like to reaasemble, press the bearing to the shaft, then press the shaft/rotor into the plate. I can make a press for it no problem too. If it works out, I may be able to offer a recoating/rebuilding service for the rotor packs.
    I looked at the pricing of who's offering it, and it's outrageous. If I can set-up a core program, I may be able to make it fairly reasonable. there are also low drag bearings available for this case, so there could be some performance benefits.
  9. #9 Re: I truly am totally nuts.
    Oklahoma
    You singing a sweet melody there Ron. I am all ears and am eager to see what you come up with.
  10. #10 Re: I truly am totally nuts.
    hangover park IL, in the garage working on one of 12 3800's
    that you are.... maybe its the chitown water
  11. #11 Re: I truly am totally nuts.
    Well, I think it's something that needs to be done. Cores are getting harder to find mint. Be nice to be able to find some extra performance in there somehow also.
  12. #12 Re: I truly am totally nuts.
    Oklahoma
    Let me ask this, as Im just curious and sorta thinking out loud. Would it be better or easier or some other advantage to coat the inside of the housing rather than the rotors themselves? Isnt the purpose of the coating to tighten up clearances?
  13. #13 Re: I truly am totally nuts.
    gun drill each lobe of the rotors, balance em, slot em for teflon strips, coat the gears...low drag bearings...where will it stop! madness i say madness lol
  14. #14 Re: I truly am totally nuts.
    Oklahoma
    Maybe, but its the kind of madness I like.
  15. #15 Re: I truly am totally nuts.
    Hoffman/Schaumburg, IL
    Most if not all the great minds and inventors were considered mad at some point
    But they died before anyone would deem them a genus, so take above with a grain of salt
  16. #16 Re: I truly am totally nuts.
    lol your awake still? lol
  17. #17 Re: I truly am totally nuts.
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Ron, now that I see what you are doing I wished I kept my 20K mile stripped rotors. Everyone said that having the coating stripped would cause you to loose boost so my were changed out for a set from Ed. There was absolutely no difference in boost level. Had that possibility occured to me, I would have kept my stock rotors.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  18. #18 Re: I truly am totally nuts.
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    question on the rotors is there supposed to be alot of play in them when they are removed. i relize that they are supposed to have some. and is there anyone that sells those bearings
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  19. #19 Re: I truly am totally nuts.
    SE Level Member TooMch's Avatar
    St. Louis, MO
    Quote Originally Posted by IndeedSS View Post
    nah, you would've found something else to do with them. You might have kept them if Ron was already doing his thing and had him recoat them. I believe you would have done that, but just keep them stripped,.... Just doesn't sound like you.
    2004 GTP CompG
    wizair| LQ4| S2IC| 3.0| 1.9RR| RS12YC| 160°| 39#|TOGX|3" Hogan DP| Corsa| tune
    2007 = 13.034 @ 103.68 (TOGX, AL103, ZZP DP)
    2004 = 14.576 @ 94.34 || 2005 = 13.822 @ 97.57 || 2006 = 13.224 @ 99.98 (PEMs,TR6IX, RT DP)
  20. #20 Re: I truly am totally nuts.
    Oklahoma
    Quote Originally Posted by TooMch View Post
    LOL. Sounds like someone knows you pretty darn well there Lee.
