Thread: Ticking at start up
Results 1 to 19 of 19
  1. #1 Ticking at start up
    iowa
    I have had my 02 gtp since april of 08 and have had no problems but just about a week or so ago it started to tick. It was weird it would be really loud but then go away as you drove it and run perfectly smooth until you let it sit over night, it has to sit over night though. It could be 8 or 9 hours without driving it and start it up and it would run fine. Let it sit overnight and start it up in the morning and it ticks. What might it be and what might fix the prblem?
    Thanks for any info and help
  2. #2 Re: Ticking at start up
    Lifter tick. It happens. Get a product called Lucas Oil Stabilizer. If it goes away then it is a lifter.
  3. #3 Re: Ticking at start up
    Apr 2009
    stockton ca
    lucas ftw
  4. #4 Re: Ticking at start up
    iowa
    Do i need to get new lifters to completely fix the problem or will this llucas stuff cure it
  5. #5 Re: Ticking at start up
    Banned - Busted For Scamming
    Feb 2009
    does it go away pretty quick? if so, dont worry about it they are still pumping up, just not holding over night
  6. #6 Re: Ticking at start up
    Dartmouth N.S.
    I had the same problem in my 03 gtp, I had run mobil 1 since I had the car , One morning out of the blue in started ticking, but would not go away. So I ended up taking it into the shop. Turned out the motor had a build up of sludge in the bottom end and would not let the oil travel to one of the back lifters until the oil warmed up and was able to travel through. he used a cleaner/conditioner and about 4 oil changes. this helped for about 1 month until it did it again? Without dropping the pan I just ran a cleaner again and it stopped.
  7. #7 Re: Ticking at start up
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Seafoam that mf'er.
    No, seriously - seafoam it.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  8. #8 Re: Ticking at start up
    Quote Originally Posted by Swash View Post
    Seafoam that mf'er.
    -Swash
    Listen to this mf'er^^
    No, Seriously - he knows his chit
  9. #9 Re: Ticking at start up
    May 2008
    McHenry IL
    haha seafoam is great and FUN stuff haha
  10. #10 Re: Ticking at start up
    iowa
    Well at first it would take a while to go away but, i started driving it to see if it would go away it did help by driving it (the tick wouldnt last as long) but it never went away. I have tried seafoam and the local mechanic gave me some other stuff that helped a little but it still has not completely gone away. So try the lucas oil stabilizer or just do the lifters or do you think it will just go away?
  11. #11 Re: Ticking at start up
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Be forewarned: This is coming straight out of my ass.
    Check the torque on your exhaust manifold bolts. Loose EM, or a leaky gasket, sounds just like a crapping lifter, then the sound goes away after the metal heats and expands....
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  12. #12 Re: Ticking at start up
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    Quote Originally Posted by Gregorius View Post
    I have this exact problem, one of my manifolds is leaking ever so slightly and as it warms up, seals itself and the tick goes away
  13. #13 Re: Ticking at start up
    Houston, TX for now
    Lucas actually makes a lifter cleaner that works very well on the infamous 3800 lifter tick. There are several guys in Idaho that replaced their lifters only to have it come back a year later. I haven't had it since I got in the habbit of using the lifter detergent.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  14. #14 Re: Ticking at start up
    Dartmouth N.S.
    How often do you use this lucas cleaner before the tick comes back? I'm only getting about 2000kms before it starts again. This tick drives me crazy thats for sure.
  15. #15 Re: Ticking at start up
    Quote Originally Posted by SuperChargedGTP View Post
    They tell you to use a measuring cup full of it every oil change or something like that...I just kinda wing it and use it until the sound goes away...the GF's 2.2 Ecotec in her Cavalier likes to tick...I hate those little DOHC motors...so noisy...the Lucas quites it down for sure.
  16. #16 Re: Ticking at start up
    Houston, TX for now
    Like blue said every oil change. Another product that has worked on a lot of 3.8's is Marvel Mystery oil. That is a every oil change as well.
  17. #17 Re: Ticking at start up
    Jersey
    I had lifter tick. I replaced my lifters. Problem went away.
    16' wrx sti- stock
  18. #18 Re: Ticking at start up
    Quote Originally Posted by 99prixgt View Post
    Good job Mr. Jackass
    LMAO!!
  19. #19 Re: Ticking at start up
    CT
    man, now that I hear this I'm wondering if my tick is from my exhaust or lifters. I'm pretty sure its the back manifold to down pipe connection but damn this has me wondering now lol. I'm going to add that lucas additive with my next oil change. Also what conditioner do you guys use? I've use seafoam and it worked amazingly for my truck.
  1. Ticking in the engine....
    By fortune4you in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-01-2010, 09:59 AM
  2. 3100 Ticking
    By LuckyPiston13 in forum General Tech Discussion
    Last Post: 07-11-2009, 09:36 PM
  3. DP ticking
    Last Post: 03-01-2009, 11:39 PM
  4. Ticking
    By theboss98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:17 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
