Thread: The Start
Results 1 to 8 of 8
  1. #1 The Start
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    The build has begun. Ya i already have quite a few mods but to me all the new stuff going on is a big deal. lol. But heres the list:
    HID 9007 (Headlights) 6000K
    HID 880 (Fogs) 6000K
    Gianelle Cairo 20"s all Black
    Mini's Full Size Phenolic Intercooler
    TDCRacing Ported S/C Housing
    Ported LIM By Mini
    New #33 Injectors
    Valve Cover Breather
    TDCRacing 10.4mm Wires
    All new Calipers
    HPTuners Software (Intense Bin. File)
    FMHE From TDCRacing
    Pacesetters going back on the car
    EGR Delete
    EVAP Delete
    Autolite 103's
    40th Anniversary/Daytona 500 Roof Rails
    Brake Hoses
    Will have pictures posted up as things start to come together. As of right now the whole car is up in the air on Jackstands with no front bumper and no wheels.
    Any help and suggestions would be very much appreciated
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: The Start
    SE Level Member lageR's Avatar
    Jan 2009
    IL
    why stock injectors on an intercooled build?
    doesn't make much sense...
  3. #3 Re: The Start
    Before deciding to do the intercooler setup, i had ordered stock injectors from ZZP. I dont quite fully understand how to do tuning yet either so i dont want to buy bigger injectors, put them on, then not be able to drive the car to the guy thats gonna tune it for me. im trying to get rid of some things so i can buy fuel logs, bigger injectors, Northstar TB and an LQ4 MAF.
  4. #4 Re: The Start
    N*? Screw that get a LS1
  5. #5 Re: The Start
    Moore, Oklahoma
    I'd recommend not going any lower than a 3.25" with those stock inj. You'll need the fuel with any smaller pulley.
    BTW, you may want to invest in some Pilot Fog Light housings and H3 blubs, you'll melt your stock fog light housing with those HIDs, been there done that myself. You'll see in a month or 2, trust me.
    I will ask, how are you planning on deleting the EVAP system? Just curious, i've been thinking about doing that myself too.....
    Shawn W. Larsen
  6. #6 Re: The Start
    Ya that makes sense. Would 42.5 injectors or whatever they are be good? And i just disconnected the line from the EVAP Solenoid and took a silicone tail pipe tube for a Traxxas Revo RC Nitro car and pushed that onto the barb on the Throttle Body and put a screw in that wouldnt fall out while driving.
  7. #7 Re: The Start
    Whats the difference between the LS1 Throttle Body compared to the Northstar Throttle Body? I personally need a 78mm to math up with the 78mm outlet on my S/C.
  8. #8 Re: The Start
    The pedal feel and throttle response is incomparable to the LS1...it is awesome.
  1. Car won't start
    By 03GTPFour in forum General Tech Discussion
    Last Post: 08-04-2009, 03:03 AM
  2. Where should I start?
    By Basher in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2009, 09:44 PM
  3. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  4. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
  5. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
