Thread: 2006 GP GT - Modding research
Results 1 to 15 of 15
  1. #1 2006 GP GT - Modding research
    SE Level Member GeeBee's Avatar
    Iowa
    Hello,
    Just bought a stock 06 GP GT and doing some research before doing any mods to it.
    Will be a daily driver, trying to keep with mods that increase power / fuel economy. Keeping A/C and Cruise control are a must.
    Mostly Decided mods
    Headers / Downpipe
    New Airbox
    Lower thermostat
    1.9 rockers
    Considering -
    ZZP Aluminum heads / matching upper intake
    85mm MAF
    Cat/Downpipe-back Exhaust
    criticism / suggestions / thoughts greatly appreciated>=D
    I am strongly considering the ZZP aluminum heads but would like some feedback for them being a daily driver and would like to know how well they work with stock cam / 1.9 rockers
    Well off to work,
    GeeBee
  2. #2 Re: 2006 GP GT - Modding research
    Donating Users blowfishRus6's Avatar
    g.a.
    you dont really need the heads. deff not for the money.
    headers, rockers (i love my rollers) intake, good tune and a smaller pulley. the maf is a good idea because the refreshes quicker and it will be more accurate.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: 2006 GP GT - Modding research
    g.a.
    right now i have intake, headers and rockers. its decent for a street car and im untuned. should be tuned pretty soon with some more boost
    also read the KR stickey. it will explain ALOT, when you drop pullies your gonna want a scan gauge.
    its slow.
  4. #4 Re: 2006 GP GT - Modding research
    Jersey
    if your thinking about heads, take the two you have to a shop and have them ported. As far as an intake, make your own. Im not sure what your d/b wire t/b looks like but if u can just stick a cone on the end of it.
    16' wrx sti- stock
  5. #5 Re: 2006 GP GT - Modding research
    g.a.
    our maf is external and would need to be in the middle of that. i would not recemend it tho. my car is such a slouch from all that hot engine air that it gets like that.
    its slow.
  6. #6 Re: 2006 GP GT - Modding research
    Jersey
    fwiw this is mine, I like my open cone
    16' wrx sti- stock
  7. #7 Re: 2006 GP GT - Modding research
    FINALLY!! YOU SHOW IT BISH!! LOL AWESOME!!
    Here's my open cone...but keep in mind to run them you have to be heavily modded or it will hurt you. Some like to argue but a bolt-ons GTP can't run a open cone and benefit
    Make your own intake and keep the filter in the fender...get headers...if money isn't a issue...then ZZP...if not get some Pacesetter's and have them welded like I did or some SSAC's. Heads are a bit much for a very small bolt-ons car...I'd do it like so...
    180* T-Stat
    Custom Fenderwell Intake
    85mm MAF
    Custom Tuned PCM
    Headers of some kind
    1.9:1 Roller Rockers w/ LS6 Valve Springs/Retainers
    Intense-Racing Poly Mounts (Upper and Lower)
    3.4" or 3.5" Supercharger Pulley
    TransGo Shift Kit
    Any farther then that...get a Stage 2 Intercooler, 3.1" Pulley, and a new tune
  8. #8 Re: 2006 GP GT - Modding research
    Jersey
    ^well said sir
    16' wrx sti- stock
  9. #9 Re: 2006 GP GT - Modding research
    g.a.
    yea a DEbenifit from an open cone. well in the winter time it was not that bad but other than that, yea i suffer from it.
    its slow.
  10. #10 Re: 2006 GP GT - Modding research
    Aug 2008
    Long Island, New York
    Quote Originally Posted by blowfishRus6 View Post
    thought you had a wizaired according to your sig??
  11. #11 Re: 2006 GP GT - Modding research
    Iowa
    Thanks much for the input
    I've decided its prolly best for me to have the tuning software so i'm doing a bit of reading on that atm>=D I tried starting with the OpenTuner 3800 and had to go to the HPTuners site and dig up thier intro / acronym list.
    Couple more Qs
    Are FWI's prone to the elements at all?
    At what point should i consider upping the factory injectors?
    -GeeBee
  12. #12 Re: 2006 GP GT - Modding research
    FWI...only if you are going through huge puddles and drive in very dirty conditions. Cover it with a filter condom if you care about it...
    Injectors...you won't need them unless you go sub 3.1" pulley.
  13. #13 Re: 2006 GP GT - Modding research
    Iowa
    Cool,
    Spent most of the day reading stuff,
    Looking to get a laptop + hptuners, but is it true the 06+s aren't supported by hptuners and you have to use an 05 pcm that requires a gauge to be swapped out to utilize? I've not purchased anything yet and sent a mail to hptuners regarding 2006+ pcm support.
    -GeeBee
  14. #14 Re: 2006 GP GT - Modding research
    I think the gas gauge flips or something...
  15. #15 Re: 2006 GP GT - Modding research
    g.a.
    Quote Originally Posted by 2000GTP View Post
    it changes all the time. im never happy with it. plus its so simple to swap around, why not.
    and my car does get alot of dirt and grime in the iner fender. but some duct tape on the inside of the fender should clear that up. i can look down threw my fender and see my tire, so alot of things it picks up from the rode is getting thrown into there. just seal it up good.
    its slow.
  1. Modding advice
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2009, 09:16 PM
  2. modding my gtp
    By scottys99gtp in forum Off Topic Discussion
    Last Post: 02-25-2009, 04:48 PM
  3. Let the modding begin!!!
    By Keet04GTP in forum Off Topic Discussion
    Last Post: 08-18-2008, 06:46 PM
