Thread: <b>please help<b>
Results 1 to 6 of 6
  1. #1 <b>please help<b>
    the desert
    my key wont go to accesory wat shuld i do
  2. #2 Re: <b>please help<b>
    SE Level Member The Chad's Avatar
    Harrisburg, PA
    Are you saying that you can't turn the key counter-clockwise to the ACC position? Or is it that you can't turn it clock-wise past the run position to start the ignition? Or is it that you can turn it clock-wise, but when in the run position (the click before ignition) that it doesn't do anyting?
  3. #3 Re: <b>please help<b>
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by The Chad View Post
    That made my head hurt.
    If the key won't turn to ACC - or anything else for that matter - make sure first that your steering wheel isn't locked over. For instance - while attempting to turn the key - also (simultaneously, at the same time, etc etc) try and turn the steering wheel in either direction and see if that releases - after which you should be able to turn the key.
    If this doesn't help you - then you may have a switch issue - or possibly a key issue. Try a spare key??
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  4. #4 Re: <b>please help<b>
    the desert
    it wont go to acc it goes to everything else smoothly i got it to acc one time i culdnt get it then i was jus like hmm ima try one more time and it went but i got lucky and it doesnt do it anymore
  5. #5 Re: <b>please help<b>
    Quote Originally Posted by mcsddd View Post
    Uhhh...ok.
    -Swash
  6. #6 Re: <b>please help<b>
    the desert
    it worked it worked i tried my spare key and it works thanks for everything everybody
