Thread: to rebuild or not to rebuild
Results 1 to 3 of 3
  1. #1 to rebuild or not to rebuild
    Plattsburgh,NY
    Ok so here is my situation, keep in mind this car is for my son so his budget is low. Bought 98 grand prix 3800 SC with 128,000 mile for 400 bucks. They said the engine knocked so I'm thinking rod bearing.The original plan was to take the 3800 SC out of his 92 park ave that the frame rusted through on. found out series one and two won't swap out. The problem with the original motor is bad oil pump valvetrain making niose. I know the pump doesn't pump changed oil and filter when pulling motor drained oil just as clean as when I put it in there and no oil in the filter. So i'm thinking check the main and rod bearings while the engine is out if clearance are ok bolt back up,if not have the crank turned and new bearing. Next worry cam bearing if cam ok then do cam bearing, how hard are these to replace? If I do cam and mains where is a good place to get parts at a good price have you guys found a web site that offers good deals? If I just do an entire rebuild about how much does the master rebuild kit cost.
    Thanks for the help.
  2. #2 Re: to rebuild or not to rebuild
    Banned - Busted For Scamming
    Feb 2009
    if youre looking at an oil pump failure, forget the bottom end. 3800s are plentiful and you can get a new bottom end for much cheaper than it would cost to machine and get oversized parts.
  3. #3 Re: to rebuild or not to rebuild
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    Ed Morad's a good guy and can get you anything you need - he's the go-to source for GP parts 97-current.
    X2 on what chopper said - if the oil pump failed - doing anything with the bottom on the ole girl is pretty much a waste of valuable time and money.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  1. 95 3100 rebuild kit?
    By JaPpEsKa in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-08-2009, 09:12 AM
  2. Gen V rebuild promblem
    By chrisb in forum General Tech Discussion
    Last Post: 04-10-2009, 08:20 PM
  3. Tranny rebuild????
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2009, 04:54 PM
  4. I need to rebuild.. Procharged???
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2008, 07:43 PM
  5. Tranny rebuild
    By GTPOWER in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2008, 03:25 AM
