Thread: Motor and tranny mounts....
Results 1 to 18 of 18
  1. #1 Motor and tranny mounts....
    Gainesville, FL
    I need to check mine for damage. I was having a vibration at WOT sometimes. I just installed AGX's/ Vogtlands/ strut mounts/ new axles and 12" brakes. The periodic vibration at WOT is way worse. It was so bad this morning from a 10mph roll that I thought I was getting wheel hop.
    Could I have a bad mount? If so, other than the one above the LF cv axle, where are the others so I can check?
    Thanks,
    Dean
    2k1 GTP Sedan, Black. 3.4, FWI, 180, PT, Borla, Headers, AL104's, GMPP handling kit, Vogtland/ AGX, 12 in brakes/SS lines/ Hawk HPS, 1.9's
    2k4 Maxima SE A5 Black, K&N, wifes
    PEMs and two 3" DP for sale.
  2. #2 Re: Motor and tranny mounts....
    Banned
    New Port Richey Florida
    there is one on the lower right front of the engine and one on the right side were the axle install's into the trans
  3. #3 Re: Motor and tranny mounts....
    GT Level Member Preotic's Avatar
    Missoula, MT
    It's most likely vibration associated with lowering. You lower the vehicle and it changes the geometry of the driveline. If it is in fact vibration associated with lowering, VinnieGTP makes some spacers you put above and below you engine and tranny mount. This raises the engine up and restores the driveline geometry. When i put mine in i decide to put new mounts in too.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  4. #4 Re: Motor and tranny mounts....
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    you can also get shorter axels. that will completely fix your vibration
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  5. #5 Re: Motor and tranny mounts....
    Saraland Alabama
    but how much are they compared to the spacers that also work?
  6. #6 Re: Motor and tranny mounts....
    Wichita, KS
    Lower our cars too much, the CV shaft no longer floats in the main housing, it bottoms out. There ya go.
    Run shorter axles, raise the engine and the transmission, or shorten the dog bones pulling the back of the engine and transmission UP, tilting the whole unit forward releaving the CV shafts from the binding.
    ~F~
  7. #7 Re: Motor and tranny mounts....
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    You can pick up the spacers from here:
    http://www.grandprixforums.net/f51/m...back-1107.html
  8. #8 Re: Motor and tranny mounts....
    Gainesville, FL
    I guess I'm perplexed because it was vibrating before it was lowered (only under WOT and not all of the time) but now it does it worse (only under WOT and not all of the time).
    My DP is making contact with my sway bar and I wonder if that is where the vibrations are coming from. That could make sense. It has been hitting for a while. I guess a bad mount might allow that to happen.
    I may try the spacers, inspect the mounts and maybe go with the shorter dogbones. Has anyone used the shorter dogbones?
    Dean
  9. #9 Re: Motor and tranny mounts....
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    it's also possible that your cv axles were a bit worn, and the geometry change has made the situation worse.
  10. #10 Re: Motor and tranny mounts....
    Gainesville, FL
    We replaced both axles with brand new when we did the springs/struts/mounts/anti pogos
  11. #11 Re: Motor and tranny mounts....
    Las Cruces, NM
    Is you swaybar installed upside down? If not, it needs to be with a 3" DP.
  12. #12 Re: Motor and tranny mounts....
    Wichita, KS
    ^some times it does.
    I have a 3" DP and a GMPP front bar, and didn't need to flip mine. Every car is different.
    ~F~
  13. #13 Re: Motor and tranny mounts....
    Gainesville, FL
    Yep, mine is flipped.
  14. #14 Re: Motor and tranny mounts....
    Las Cruces, NM
    You also have the smallest of aftermarket bars, if it really even makes a difference.
  15. #15 Re: Motor and tranny mounts....
    Wichita, KS
    its not the size of the bar, its how you use it. LOL
    ~F~
  16. #16 Re: Motor and tranny mounts....
    Wilbraham MA
    what does dp stand for?
  17. #17 Re: Motor and tranny mounts....
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Quote Originally Posted by Chizzler View Post
    Wow, holy old thread retrieval Batman. Well, at least you searched...
    DP is an abbreviation for down-pipe (comes off rear exhaust manifold).
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  18. #18 Re: Motor and tranny mounts....
    Wilbraham MA
    Thanks
  1. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  2. My new aluminum motor mounts
    Last Post: 01-24-2008, 10:04 PM
  3. tranny
    By bad1999gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 02:04 PM
  4. Powdercoating brakes/mounts [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 12-17-2007, 03:41 PM
