Thread: Engine Rumbling/Knocking, HELP Please :)
Results 1 to 10 of 10
  1. #1 Engine Rumbling/Knocking, HELP Please :)
    St. Paul Minnesota
    SO i just bought a 97 gtp sc, it's got some issues that i figured a car it's age would have, passenger window wont go up... when i listen to the engine with my window down i hear a rumbling, like i can hear the pistons. Seems louder than i think it should sound, but i have no idea how it should sound. Guy at Jiffy lube told me it could be the exhaust manifold. I need some idea of what it could be.
  2. #2 Re: Engine Rumbling/Knocking, HELP Please :)
    Any SES lights? Pull the spark plugs to see if any of them are damaged...might have a chipped piston but not likely...or try to get a video of it?
  3. #3 Re: Engine Rumbling/Knocking, HELP Please :)
    St. Paul Minnesota
    What are SES Lights? I guess i could take a video, the engine seems to operate ok. nothing really lacking power, just noisy. like i can almost hear the pumping.
  4. #4 Re: Engine Rumbling/Knocking, HELP Please :)
    Service Engine Soon
  5. #5 Re: Engine Rumbling/Knocking, HELP Please :)
    St. Paul Minnesota
    No, there isn't service engine soon lights on. Jiffylube guy told me it sounded like an exhaust issue, but it sounds close to the motor, cuz i can hear the pistons pumping, idk. would take the exhaust off be very difficult?
  6. #6 Re: Engine Rumbling/Knocking, HELP Please :)
    Feb 2008
    San Diego, CA
    Get a video so we can hear the sound.
  7. #7 Re: Engine Rumbling/Knocking, HELP Please :)
    Banned - Busted For Scamming
    Feb 2009
    supercharger coupler?
  8. #8 Re: Engine Rumbling/Knocking, HELP Please :)
    I'm still voting for a video of this...maybe busted flex or mounts...
  9. #9 Re: Engine Rumbling/Knocking, HELP Please :)
    St. Paul Minnesota
    i dont have a camera. I also dont have the supercharger belt on. I have no idea how to get it on. i tried to put it on one day. found the piece that moves, but still doesn't want to fit. I think the guy at autozone gave me the wrong belt.
  10. #10 Re: Engine Rumbling/Knocking, HELP Please :)
    This is straight from ZZP on most any belt you'll ever need...
    Stage 2 IC
    685 - 6-rib, 3.3"+
    680 - 6-rib, 2.90" - 3.20"
    08-685 - 8-rib, 3.0" - 3.20"
    08-680 - 8-rib, 2.60" - 2.90"
    Stage 3 IC
    680 2.6-3.0
    685 3.1+
    25060721 72.625" stock bonneville
    25060716 72" for 3.4" bonneville
    25060670 SS IC with 3.2+ SS IC
    4060660 - GTP/GS/SS supercharged with 3.2 - 3.5" pulley
    4060650 - GTP/GS/SS supercharged with 2.9 - 3.1" pulley
    060716 - Bonneville SSEi with a 3.4" pulley
    060670 - ss IC with a 3.2"+ pulley
    060667 - Stock GTP or ss IC with 3.0" pulley
    675 - Gen 5 blower S3 core 2.3"-2.55", Stage 2 core 2.4"-2.60" pulley
    060680 - ?Stage 2 intercooler 2.6 - 2.8" pulley
    Gen 5 blower S3 IC 2.6"-2.9", S2 IC 2.7"-3.0" pulley
    060685 - Gen 5 blower, stage 3 IC 3.0+ pulley
    ?Stage 2 intercooler 2.9 - 3.1" pulley
    060915 - Stock accessory belt for '99-03
    -also works with either UD WP pulley or OD alt pulley but not both
    060923 - Accessory belt for 99+ with UD WP pulley and alt UD pulley
    060905 - Stock accessory belt for '04+
    060935 - Stock accessory belt for 97/98 (94")
    060938 - Accessory belt for 97/98 with underdrive pulleys
    060970 - SS M90 for 97/98
    060950 - SS M90 for 99+
    915 99-03 stock accessory belt
    923 99-03 for underdrive water pump and Alt pulley
    905 04+ stock accessory belt
    935 97/98 stock accessory belt
    938 97/98 for underdrive water pump and Alt pulley
    667 stock S/C belt for GTP, GS, SS
    658 GTP, GS, SS S/C belt for 3.5-3.25 pulley
    650 GTP, GS, SS S/C belt for 3.2-3.0 pulley
    721 stock Bonneville SSEi Supercharger belt
    716 Bonneville with 3.5-3.25 S/C pulley
    875 99-03 accessory belt with Meziere water pump
    864 04+ accessory belt with Meziere water pump
    895 97/98 with Meziere water pump
    685 S/C belt s2/s3 ic 3.0-2.8 pulley (depends on tensioners)
    680 S/C belt s2/s3 ic 2.7-2.55 pulley (depends on tensioners)
    670 S/C belt ss ic with 3.2+ pulley
    667 S/C belt ss ic with 3.2-3.0 pulley
  1. Squeaky brakes/Engine Knocking
    By crusinchub in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2009, 07:34 PM
  2. Poly mounts...knocking sound
    Last Post: 05-16-2009, 03:48 PM
  3. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
  4. engine knocking
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 01:50 PM
