Thread: Help quick! Coolant bleed?
Results 1 to 4 of 4
  1. #1 Help quick! Coolant bleed?
    Ohio
    Alright i need some help guys/gals. I seem to have forgotten how we bled my coolant when i did my lim gaskets an my thermo had a leak so i had to pull it off an replace the gasket. So now i need your help. How do i bleed the coolant? I know it involves a sequence of the radiator cap the bleeder valve and running the engine i just dont remember how it went.
    00 GTP demodded and forsale
  2. #2 Re: Help quick! Coolant bleed?
    SE Level Member oldschoolpontiacs's Avatar
    Feb 2009
    BC Canada
    I just left the radiator cap and the bleeder open. By the time the t-stat had opened and closed twice there was nothing but fluid coming out of the bleeder, so I closed it all up and called it a day. It's been on the road for 2 days now with no air bubbles
    Sisters car: 1997 4-door GTP
  3. #3 Re: Help quick! Coolant bleed?
    Charles City, IA
    Yup let the car heat all the way up with the heater on. Break open the bleeder (7mm) wait till only coolant comes out, top off the rad/ overflow tank then you are done.
    SMGPFC Two Nipple General
  4. #4 Re: Help quick! Coolant bleed?
    Ohio
    Thanks guys. Got it all done. No more leaks. Coolants bubble free
  1. Just a quick Q
    By 1998xGTP in forum Forum Bugs/Suggestions
    Last Post: 03-30-2009, 02:12 PM
  2. quick 1 HID question
    By wildkyle90 in forum Visual/Body Modifications
    Last Post: 12-14-2008, 04:16 PM
  3. Quick PF question
    By BluFlameGTP in forum General Tech Discussion
    Last Post: 12-09-2008, 01:13 PM
  4. Please Help Quick!
    By 2tone bullit in forum General Tech Discussion
    Last Post: 05-22-2008, 07:37 AM
  5. Help quick
    By evlprx in forum General Tech Discussion
    Last Post: 02-24-2008, 07:16 PM
