Thread: S&S Header Install
Results 1 to 19 of 19
  1. #1 S&S Header Install
    I just picked up a set of used S&S headers. I was wondering if anyone has any tips or advice for me.
    So I take it these need a doughnut gasket correct? Where should I get one?
    Also, as far as the rear header, what all are people needing to remove to drop these particular ones in? Am I gonna need a trans dipstick from zzp?
    Any input wold be much appreciated. Thanks.
  2. #2 Re: S&S Header Install
    id get ahold of S&S for the donut gasket. they are really easy to install. pull your EGR and get the motor as far forward as you can with the dogbones out to put the rear header in. the rest is a snap.
  3. #3 Re: S&S Header Install
    I guess my biggest concern was the trans dipstick, and any other objects that might be in the way. Also I noticed that one of the flanges was a little bent. One of the crossover ears is kinda bent inward implying over tightening.
  4. #4 Re: S&S Header Install
    the trans dipstick is a little funny. it has a hole at on a flange that gets bolted to the transmission, but i hogged out that hole so it was a slot instead. i then put a couple washers on that bolt so i could move around the dipstick and then tighten it down out of the way of the headers.
  5. #5 Re: S&S Header Install
    Interesting. Is that what people are doing then? I didnt really want to buy a prebent one from zzp. I would like to keep the cost down if possible.
  6. #6 Re: S&S Header Install
  7. #7 Re: S&S Header Install
    Does anyone know where I can get a new doughnut gasket from?
  8. #8 Re: S&S Header Install
    Does S&S not sell them?
  9. #9 Re: S&S Header Install
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I removed the Trans dipstick and slid my rear header right in and bolted it back in and it has good clearance. Mine are SSAC though
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  10. #10 Re: S&S Header Install
    Yeah each header has it's downsides...Pacesetter's leak, TOG's are a PITA, SLP's tick like crazy...you get the idea...
  11. #11 Re: S&S Header Install
  12. #12 Re: S&S Header Install
    Does anyone know of a place that I could get a new doughnut gasket from besides S&S? I called them and they said that it was 25 bucks. Personally I thought that was a little on the expensive side. Any suggestions?
  13. #13 Re: S&S Header Install
    Bump
  14. #14 Re: S&S Header Install
    Honestly...get the part and do it right...I've learned not to take ANYMORE short cuts...trust me
  15. #15 Re: S&S Header Install
    Naugatuck CT
    25 bucksto have a good header install is worth it
  16. #16 Re: S&S Header Install
    I went to a local exhaust shop down the street from my house and picked one up for five bucks. I am looking forward to the install of these. All I need now is an o2 extension harness and I am all set. I cant wait.
  17. #17 Re: S&S Header Install
    Naugatuck CT
    just make your oun cut the wires and splice wires on to make it longer solder if you want or butt splice
  18. #18 Re: S&S Header Install
    I was going to, but I relocated the sensor pretty far away. Plus I kinda like the idea of wetherpack sealed harnesses. Also Caspers is not far from my house.
  19. #19 Re: S&S Header Install
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    Quote Originally Posted by GRANDPRIXFOOL01 View Post
    I added 3ft of wire to mine (completely unnecessary), I just didn't want it to be too short.
    Call me Brad
    '06 GT: Just a few mods here and there.
  1. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  2. Header Install this weekend.
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 12:29 AM
  3. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
  4. OBX Header Install is done finally!!
    By Uno99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2009, 12:11 AM
  5. Bad vibration after header install
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 09:08 PM
