Thread: Cooling fans always on?
Results 1 to 4 of 4
  1. #1 Cooling fans always on?
    SE Level Member oldschoolpontiacs's Avatar
    Feb 2009
    BC Canada
    Sisters car is wrapped up and runs great, but both fans come on as soon as I start the car...ideas?
    Sisters car: 1997 4-door GTP
  2. #2 Re: Cooling fans always on?
    TDCRacing
    Guest
    Your coolant tempeture sensor is bad or your A/C is on.
  3. #3 Re: Cooling fans always on?
    Banned - Busted For Scamming
    Feb 2009
    pretty much
  4. #4 Re: Cooling fans always on?
    Feb 2009
    BC Canada
    Well a/c is as off as I can get it, but the HVAC controls aren't functioning the way they should, at least 2 fan speeds don't work. The a/c is empty, it has been since she bought it, would disconnecting the pressure switch and/or compressor do the trick? Coolant temp seems to read okay if not a little on the low side on the dash, but does it send seperate signals out or just one that splits?
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  3. COuple random cooling issues I need a little help with
    By REBELoffaLEASH in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-06-2009, 01:00 AM
  4. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
  5. Cooling fan swtich
    By bkaab in forum General Tech Discussion
    Last Post: 04-11-2008, 10:54 PM
