Thread: Blower swap question
Results 1 to 6 of 6
  1. #1 Blower swap question
    SE Level Member Infinity9999's Avatar
    Dec 2008
    Brookfield, WI
    How much coolant do you need to drain to pull the blower off of the car? Or is it not necessary to drain any and just clean up any that leaks out and top off when you're done?
    04 Black GTP Comp G
    Mods: 3.2 pulley, SSIC, Wizair, AL104s, OBX headers, VS cam, 105# springs, 42# injectors, PowrTuner
  2. #2 Re: Blower swap question
    Banned - Busted For Scamming
    Feb 2009
    you wont need to drain for that, its the highest point. drill and tap and block off those holes for next time so that you wont have to worry about it.
  3. #3 Re: Blower swap question
    Yup, I quiksteeled the 2 Coolant passages in my LIM so I wouldn't have to worry about that crap any longer.
  4. #4 Re: Blower swap question
    i drilled and tapped mine as well. coolant in the blower and TB just keeps things hot.
  5. #5 Re: Blower swap question
    Feb 2009
    fwiw, my current lim is welded , what coolant holes....
  6. #6 Re: Blower swap question
    PORT THE SIDE PART OF THE LIM THAT LETS COOLANT FLOW!!!
    otherwise your rear head will run hot and prematurely fatigue. seriously.
  1. Gen V Swap, Noisey Blower Now
    By scottmmckinney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2009, 12:21 PM
  2. Gen V Swap, Slow Blower Boost
    Last Post: 04-10-2009, 04:19 PM
  3. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
  4. what is required for a gen 5 blower swap?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:55 PM
