Thread: Oil Pressure Fluctuation
Results 1 to 11 of 11
  1. #1 Oil Pressure Fluctuation
    So...when I start the car a little blue smoke comes out but nothing really after that. It'll sit around 50psi for a few miles but once she warms up I can watch it slowly drop...it gets scary low too...probably around 5-10psi when idling...which btw it is around 1200rpms since my IAC is bad...and I am kinda afraid to replace it and let it idle even LOWER IF I give it gas though like in traffic, off from a stop light it'll go back up to almost 40-50psi, but slowly drop back down. There are no visible oil leaks coming from anywhere either. Granted I haven't check the oil pan...gonna do that tomorrow. Any ideas guys? She runs fine otherwise...no SES lights except for my IAC and No Converter codes. Could a bad seal on my valve covers cause a loss in oil pressure? I can pop those on and off really quickly so that would nice if it is a possibility. I have a video but it is over 100MB which is too big for photobucket...gonna try to get a shorter clip today.
    TIA guys!!
    btw...WAHOO!! 2,000 posts
  2. #2 Re: Oil Pressure Fluctuation
    my car idles at 10 psi with running 10w-40. 10psi for every 1000 RPM, that is the rule.
  3. #3 Re: Oil Pressure Fluctuation
    Banned - Busted For Scamming
    Feb 2009
    Thought we already went over this.... The SPEC for the 3800 is 60psi @ 1850RPM. If you do not have that, then you have either a bad pump, bad bearings somewhere, or a bad pressure relief spring for the oil pump. Do not drive that motor with that oil pressure, youre going to kill it.
  4. #4 Re: Oil Pressure Fluctuation
    Well...it's odd...changed the oil/filter...which I WASN'T low on...and now it idles at 50 or so...drops to about 30-40 when I put it into gear but everything else checks out...damn car...I'll let you guys know how she does on the road.
  5. #5 Re: Oil Pressure Fluctuation
    Feb 2009
    are you using a mechanical gauge?
  6. #6 Re: Oil Pressure Fluctuation
    Hell no...no way I am running a oil line into my interior
  7. #7 Re: Oil Pressure Fluctuation
    PA
    What oil/filter were you running before? How many miles/months on oil/filter. What oil/filter are you running now?
    2001 GSE
  8. #8 Re: Oil Pressure Fluctuation
    Feb 2009
    i doubt the accuracy of electric gauges.... that could be your problem
  9. #9 Re: Oil Pressure Fluctuation
    if you have 10 psi of oil pressure at idle there is nothing wrong with your car. if youre really worried about it run a higher weight oil.
  10. #10 Re: Oil Pressure Fluctuation
    Feb 2009
    theoretically, 10psi should be fine but on these motors, run high oil pressure. if you see less than 40psi at idle, there is something wrong.
  11. #11 Re: Oil Pressure Fluctuation
    Barksdale AFB, LA
    I've seen old oil do what bluegtp was describing. It breaks down as it ages and its viscosity drops like a rock as it warms up. It becomes incredibly thin warm and the oil pressure thus drops. Oil change is all it needs.
    Not sure what oil he's running, but it could be a sign of crappy oil.
    2009 Subaru Impreza WRX STI
  1. Oil pressure light came on help....
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 06:59 PM
  2. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  3. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
  4. Low Oil Pressure?!?!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 03:07 PM
  5. Oil Pressure Sensor
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2008, 12:11 PM
