Thread: Serpentine Belt Trouble
Results 1 to 5 of 5
  1. #1 Serpentine Belt Trouble
    Dallas TX
    I'm replacing the alternator on my 98 Pontiac Grand Prix GTP and having problems releasing the tension on the belt. I have found the tension pulley but not sure where the bolt is to replace. Thanks to anyone that can help. This is also my first time to post to this forum and will highly recommend the site. Thanks again.
  2. #2 Re: Serpentine Belt Trouble
    TDCRacing
    Guest
    Be sure you posting in the correct section
  3. #3 Re: Serpentine Belt Trouble
    St. Louis Mo.
    Moved to the correct section.
    James Shafer
    St. Louis MO
  4. #4 Re: Serpentine Belt Trouble
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I'm not sure here, but it sounds like you're thinking of the older style tensionsers where you loosen a bolt and slide it to relieve tension on the belt. These are spring loaded tensioners, you just put a breaker bar on the bolt in the middle of the tensioner pulley and turn it to relieve the tension.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Serpentine Belt Trouble
    PA
    Using the picture I posted, you want to put a 15mm socket or wrench on the bolt in the center of the rear most pulley #3. This sits just below the alternator. Then you want to push towards the rear of the car. This bolt is left handed thread, so it may seem odd. But this will release the tension on the tensioner and allow you to remove the belt.
    2001 GSE
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. S/C Trouble...
    By LaCabra in forum General Tech Discussion
    Last Post: 04-01-2009, 09:45 PM
  3. --> Serpentine Belt & PULLEY Replacement Install H@lp <--
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 11:29 PM
  4. serpentine tensioner
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 08:20 PM
  5. serpentine belt
    By keenan00gtp in forum General Tech Discussion
    Last Post: 01-25-2009, 11:43 AM
