Thread: died
Results 1 to 6 of 6
  1. #1 died
    Jan 2009
    P_town
    MY was driving my stock 02 gtp on the highway doing about 60 mph and it hesitated, i had to tow it home due it not starting back up it will not start up but when u turn the key it starts but doesn't turn over i changed the fuel, checked for spark, battery recharged what else could it be anyone got anything. and its not running any codes, work done to it just a intake filter.
  2. #2 Re: died
    Willoughby, Ohio
    sounds like ur engine stopped takin fuel how about the pump?
  3. #3 Re: died
    Jan 2009
    P_town
    well i hear the fuel pump siphon fuel as well as on the fuel rail there is a purge nosel n there is fuel coming out of there when i purged it.
  4. #4 Re: died
    Clyde, AB
    Fuel Pump Resistor. I had the same problem with my 98 GTP.
  5. #5 Re: died
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    If its the fuel pump resistor i believe the car turns over and runs for a few seconds (at least mine did.)
    If you do determine this is your problem read this. It happened to me so i have a thread about it, a temp fix and a gm part number when you decide to replace it.
    2006 Grand Prix GXP
  6. #6 Re: died
    Wausau, WI
    problem solved? or at least pinpointed? What do you mean it starts but doesnt turn over? Did you mean it does turn over, just doesnt start? Does it start and die or doesnt it start at all........please clarify. This could be a CPS(crank position sensor) if it wont start........
  1. died
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2009, 06:21 AM
  2. I've died and gone to heaven
    By nutcase in forum Introductions/Noob Questions
    Last Post: 09-26-2008, 06:49 PM
  3. gauges died
    By uti grand prix in forum General Tech Discussion
    Last Post: 09-22-2008, 09:32 PM
  4. 3t40 just died
    By 64 gp in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 06-02-2008, 07:49 PM
  5. Help, my cluster died...I think
    By nascarnate326 in forum General Tech Discussion
    Last Post: 01-24-2008, 06:34 PM
