I was lookin into getting either an XP cam from ZZP or the thrasher cam. The thrasher has a higher lift. Is that better? Also how do these or any cam effect drivability? Now obviously when i do the cam i"m gona do the double roller timing chain, 105 or the 130 pound springs etc. Now the bigger question is can you put on a different ratio rocker on opposed to the stock 1.6? How does all this work and whats a SWEEEEET combination of parts to get some awesome performance out of your stock heads?
