Thread: weird problem???
Results 1 to 3 of 3
  1. #1 weird problem???
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    so i started the car tonight and was running the defrost a bit and noticed a weird noise comming from the engine. under a closer look, i noticed the a/c compressor was engaging and disengaging and letting out a puff when it disengaged. when i held a higher rpm the clutch stayed engaged. other symptoms include aroubnd 600rpm idle, and under WOT i was not showing full boost on the DIC....did not feel like there was any power loss... anyone have any ideas? i will be heading to get codes pulled 2morrow morning....
    '01 GTP mods: K&N intake, autolite 104's, drilled 180*, !u-bend, !EGR, ported s/c, polished heads and TB and a LOT more whine
    '99 firebird mods (1 of 6): LS1 swap, custom exhaust, LS6 IM, RA intake, and a few suspension parts
  2. #2 Re: weird problem???
    Ummm post the codes that might help
  3. #3 Re: weird problem???
    Aug 2008
    denver, co
    by the time i got to the store the only codes were my egr...nothing else and symptoms had disappeared
  1. Weird noise problem!
    By GTP4 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 11:41 AM
  2. Weird Trans problem
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2009, 01:27 PM
  3. Weird charging problem
    By xerxescct in forum General Tech Discussion
    Last Post: 02-07-2009, 08:14 PM
  4. weird...
    Last Post: 10-15-2008, 10:56 PM
  5. Weird tranny problem
    Last Post: 04-03-2008, 07:51 AM
