Thread: Heater inlet hose
Results 1 to 3 of 3
  1. #1 Heater inlet hose
    Apr 2009
    South Carolina
    Can someone here tell me which hose is the inlet hose for the heater core? If i'm looking at the firewall is it the top or bottom hose? I have a 2003 GT
  2. #2 Re: Heater inlet hose
    SE Level Member Talsition's Avatar
    Stevens Point, WI
    well if its set up like my 98 gtp its the one on the bottom on the firewall but is on top when it reaches the motor. Just had pin size holes in both and had to replace both of them.
    98 Grand Prix GTP - Custom FWI, 104 autolites, 180* t-stat, TDR Fbody Break Kit
    95 Eagle Talon ESI - 2Gb Conversion, lots of mods still slow.
  3. #3 Re: Heater inlet hose
    SE Level Member 3859c1's Avatar
    Nov 2009
    Iowa
    Hi, where did you find the inlet hose? I have located the outlet hose at a local parts store, but I can't find the inlet hose.
    Thanks,
    Darin
    1997 GTP coupe - drilled 180 thermostat, ZZP 3.4" mps, ZZP stainless Powerlog, 3" ZZP downpipe, cat delete, resonator delete, JMB fwi, alternator voltage booster, alternator power cable rewire, ZZP tune...
    www.hiliteperformance.com
  1. 2005 Grand Prix heater inlet hose?
    By xctment in forum General Tech Discussion
    Last Post: 01-17-2009, 08:43 PM
  2. location of heater inlet hose on 1994 grand prix?
    By bimple in forum General Tech Discussion
    Last Post: 01-01-2009, 06:37 PM
  3. vaccum hose?
    By kingd44 in forum General Tech Discussion
    Last Post: 10-13-2008, 05:35 PM
