Thread: 8 rib help! asap please!
Results 1 to 20 of 21
  1. #1 8 rib help! asap please!
    SE Level Member kamper98's Avatar
    Mandan, North Dakota
    Hey guys. I installed an 8 rib setup and when the car idles down in gear only there a rubbing sound and the belt jumps a little. Tried moving the MPS hub in and out, nothing worked. Tried messing with the new idlers and put a new tensioner on. Still nothing. Im running out of ideas. Maybe idle is set too low in the tune? Any help would be appreciated.
    S2 I/C, ZZP FMHE, 3.0", TOGS, FWI, 3" DP, 42.5 lb. injectors, 1.9's, 104's, Fuel pump rewire, Flowmasters, ZZP machined intake, N*, LQ4, ZZP Fuel Logs w/ PRJ regulator, AN Fuel lines, Ported I/O Gen 3, F-body 12in Brakes, 8 rib, HPTuner
    Car SOLD
  2. #2 Re: 8 rib help! asap please!
    ok. heres a video to help explain whats going on.Pictures by kamper98 - Photobucket
    Car SOLD
  3. #3 Re: 8 rib help! asap please!
    No one has any insight?
    Car SOLD
  4. #4 Re: 8 rib help! asap please!
    i have no idea unless the spring in your tensioner isnt strong enough, but that doesnt make sense to me. it seems like it is slipping on the crank pulley or something.
  5. #5 Re: 8 rib help! asap please!
    Banned - Busted For Scamming
    Feb 2009
    does the car feel like its missin out?
  6. #6 Re: 8 rib help! asap please!
    No it doesnt feel like its missing. I took the s/c belt off and it runs absolutely perfect. This is what really puzzles me. I even put the 6 rib belt on it and it still does it so i know its not the belt thats hitting. I was leaning towards one of the 8 rib idler pulleys. i wouldnt think the crank pulley would be messed up?
    Car SOLD
  7. #7 Re: 8 rib help! asap please!
    are any of the idlers stuck? maybe you tightened one down too much?
  8. #8 Re: 8 rib help! asap please!
    Ill check the idlers out tonight and let you guys know what i find. Thanks for the help.
    Car SOLD
  9. #9 Re: 8 rib help!
    Idlers seem to be running good. I emailed zzp about this and sent them the video and i got a reply of " its a misfire." I guess i dont see how this could be a misfire cause if you take the s/c belt off it runs smooth as can be. And when it is idling the s/c belt is the only one that does this. I just finished rebuilding the snout today and that didnt help any. Any other ideas?
    Car SOLD
  10. #10 Re: 8 rib help! asap please!
    when you take off the blower belt, does the supercharger pulley still spin on its own? if not, it is possible that you tightened down the blower funny and it is binding. that would be VERY bad if youre running the car like that.
  11. #11 Re: 8 rib help! asap please!
    Yeah you can take the belt off and spin the s/c by hand
    Car SOLD
  12. #12 Re: 8 rib help! asap please!
  13. #13 Re: 8 rib help! asap please!
    No it doesnt feel like it is binding. i though the same thing thats why i rebuilt the snout, but it didnt help any with the belt jumping.
    Car SOLD
  14. #14 Re: 8 rib help! asap please!
  15. #15 Re: 8 rib help! asap please!
    Thanks for all the help though! Really appreciate it
    Car SOLD
  16. #16 Re: 8 rib help! asap please!
    Barksdale AFB, LA
    Here are the things I would check.
    Belt tension
    Pulley alignments
    Pulley movement
    Belt type and length
    If all of that check out then there's no reason it shouldn't work.
    2009 Subaru Impreza WRX STI
  17. #17 Re: 8 rib help! asap please!
    ok, Belt tension: New tensioner
    Belt size: had a 08685 went to a 08680. no effect
    Pulley movement: doesnt seem to turn really hard or really loose that i have noticed. took them off and spun them by hand, spun about 2 or 2.5 turns.
    Alignment: should be the same as the old setup using the same mounting correct?
    Also do you think this could be caused by the balancer?
    Car SOLD
  18. #18 Re: 8 rib help! asap please!
    Barksdale AFB, LA
    Quote Originally Posted by kamper98 View Post
    Unless it's slipping on the balancer, I don't see how it could do it to the SC belt and not the accessories belt.
  19. #19 Re: 8 rib help! asap please!
    Thats kinda what i was thinking too. I really dont know what to do.
    Car SOLD
  20. #20 Re: 8 rib help! asap please!
    Barksdale AFB, LA
    What balancer are you using?
  1. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  2. I need a l67 asap !!!!!!!!
    By hatrain32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 09:25 AM
