Thread: Pulley bolt removal
Results 1 to 8 of 8
  1. #1 Pulley bolt removal
    Dec 2008
    Montgomery County
    I have a 1998 GTP. I'm looking to replace the serpentine idler and tensioner pulleys on the supercharger side. I'd assume that the pulley bolts loosen opposite from the direction the pulleys turn during normal operation.
    In that case the tensioner pulley (#3) loosens clockwise as does idler pulley (#9) (with the Torx T50 head) since they both turn counterclockwise during normal operation.
    Idler pulley (#8) loosens counterclockwise since it turns clockwise during normal operation.
    Can anyone please confirm this?
    Thanks
    Pulley bolt removal Attached Images
  2. #2 Re: Pulley bolt removal
    GT Level Member Preotic's Avatar
    Missoula, MT
    All the pulley loosen with right hand threads(normal) and one( can't remember which one) is left hand.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  3. #3 Re: Pulley bolt removal
    PA
    There are two #3 pulleys. One for the alternator tensioner, one for the supercharger tensioner. Pulley #3 on the supercharger side is removed with a 15mm and is right hand thread. Pulley #3 on the alternator side is removed with a 15mm and is left handed tread. Pulleys #8 & #9 bolt are right handed thread.
    2001 GSE
  4. #4 Re: Pulley bolt removal
    Dec 2008
    Montgomery County
    Thanks Zef!
  5. #5 Re: Pulley bolt removal
    SE Level Member KevSorbo's Avatar
    Socal
    Aggghhhh, I was trying to take the Tensioner Pulley off on the Accessory side with no success. I was trying to take it off w/old fashion counter clockwise as the other ones...Going left.
    So I should go clockwise (Turn Right) to loosen it up. I'll do it tomorrow if so.
  6. #6 Re: Pulley bolt removal
    Quote Originally Posted by KevSorbo View Post
    Righty Tighty...Lefty Loosey...backwards...magical.
  7. #7 Re: Pulley bolt removal
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^^^ you are correct sir!!!
  1. Caliper pin bolt
    By IndeedSS in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2008, 12:29 PM
  2. Bolt Ons?
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-03-2008, 10:06 PM
