Thread: only 4 lbs boost???
Results 1 to 14 of 14
  1. #1 only 4 lbs boost???
    calgary A.B
    Hey everyone. hopefully i put this in the right spot, if not let me know. I just recently did a topswap on my 97, everything went well....but how do i get more boost. The factory gauge only goes up about 3 or 4 lines at full throttle, i hooked up a boost gauge and it only hits 4 if im lucky, can someone please help me fix this..
  2. #2 Re: only 4 lbs boost???
    Barksdale AFB, LA
    Do you have the boost bypass solenoid hooked up?
    2009 Subaru Impreza WRX STI
  3. #3 Re: only 4 lbs boost???
    calgary A.B
    hey, thanks for the reply. Ive got it hooked up and i think correctly... and ive tried adjusting it up and down but that doesent seem to make a differance..? how many lines should appear on the factory boost gauge if its working properly?
  4. #4 Re: only 4 lbs boost???
    take off the computer control of the BBV and leave the lower vacuum line off of it and open. end your vacuum lines at the FPR. you will not have full boost.
  5. #5 Re: only 4 lbs boost???
    calgary A.B
    thanks ,but i dont quite understand you.. if i leave it open will it help me get full boost cause its hooked up now and i dont have full boost?? sorry im a newbie to the boost thing
  6. #6 Re: only 4 lbs boost???
    Bastard Reptile's Avatar
    Kansas City, MO
    The GT PCM isn't calibrated to read boost correctly. I"ve found this out on a couple of cars lately....that is if you are using a GT PCM.... Maybe I'm misunderstanding the topswap part.
  7. #7 Re: only 4 lbs boost???
    yes, the GT pcm cannot control the BBV correctly. leave the wiring off that goes to the PCM and remove the lower vacuum line from the BBV. it will then run off vacuum alone and you will get full boost, but the PCM will no longer be able to cut boost on shifts or torque management which isnt a big deal so long as you get it tuned so it doesnt bite you in the ass later.
  8. #8 Re: only 4 lbs boost???
    May 2008
    McHenry IL
    intense pcm will solve your issue =]
  9. #9 Re: only 4 lbs boost???
    calgary A.B
    Ahhhhh, got it now, thanks alot guys, i will try it..
  10. #10 Re: only 4 lbs boost???
    Quote Originally Posted by GTPJOE90 View Post
    no it wont...
    why do you think that would be a good piece of advise?
  11. #11 Re: only 4 lbs boost???
    calgary A.B
    Hey bio248, could i put a 3.4 inch pulley on , the mods i have are tuned pcm, cold air in fenderwell, colder plugs and a 180 thermostat, is there more i would have to do?? thanks
  12. #12 Re: only 4 lbs boost???
    no. do not put a smaller pulley on yet. you need some exhaust work first. you need at least a 3" downpipe to even think about a pulley. just think of it this way: to put more air in the engine you need a way for it to get out, right?
  13. #13 Re: only 4 lbs boost???
    no it wont...
    Noob advice = NO BUENO!!
  14. #14 Re: only 4 lbs boost???
    calgary A.B
    alright thanks man that will be my next mod i guess..
  1. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  2. max boost with 2.9 pulley?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 10:32 AM
  3. How much boost with a 3.4 pulley?
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:21 PM
  4. Spittin on boost
    By jakeb157 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-07-2008, 09:38 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
