Thread: Vacume Tree question & Pcv question
Results 1 to 7 of 7
  1. #1 Vacume Tree question & Pcv question
    Jersey
    Where does the middle nipple go? I have seen them capped and some not capped.
    How would i connect this pcv to properly function? I looked at the pcv harness on my L36 and there is 3 wires on it. This pcv has a 2 wire harness female plug.
    16' wrx sti- stock
  2. #2 Re: Vacume Tree question & Pcv question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Middle port on the tree is for the HVAC system, it actuates the blend doors. On the L36, it's connected where the brake booster is connected.
    The second pic appears to be an EVAP purge solenoid, maybe? Can't tell for sure, but it's not part of the PCV system. I don't have a wiring diagram handy.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Vacume Tree question & Pcv question
    Barksdale AFB, LA
    Quote Originally Posted by Scimmia View Post
    Yep. You see it capped on some engines because 04+ Impalas/Montes and a lot of Bonnies have electronic HVAC systems, so no need for a vacuum line. I got lucky and mine came capped, so I don't need to find a cap for it.
    Yep, looks like the EVAP solenoid. The PCV system has no electronics...
    2009 Subaru Impreza WRX STI
  4. #4 Re: Vacume Tree question & Pcv question
    Jersey
    where that evap solenoid goes on my gen v is right below the pcv valve (where everyone seems to block it off and run a breather instead) I am un-sure how to properly connect that evap since i don't want un-metered air entering from a breather and possibly go to lean.
    I broke my old vacuum tree where that middle nipple was blocked off, I got a new one and its no longer capped. My Hvac is all electronic. Do i need to tap into that nipple or cap it? If i should cap it, instead could i run a line from a boost gauge to that nipple?
    16' wrx sti- stock
  5. #5 Re: Vacume Tree question & Pcv question
    QCA, IA
    All electronic on a 99 GP GT? First I've heard of that, even the electronic control units use vac to control the doors, I believe.
    No go on the boost gauge to that nipple, it's before the supercharger
  6. #6 Re: Vacume Tree question & Pcv question
    Jersey
    ah yes that makes sense with the boost gauge. I guess I have to run a line from the tree to the hvac? im not sure...
    16' wrx sti- stock
  7. #7 Re: Vacume Tree question & Pcv question
    Barksdale AFB, LA
    If you have vacuum operated blend doors (which you do, since all 97-03 GPs do) and want them to work, yes you need to run a vacuum line to that port.
  1. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
  2. Question
    By james5301985 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 11:23 AM
  3. Another Question...
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2008, 01:33 AM
  4. ac question
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2008, 09:03 AM
  5. whats the shade tree
    Last Post: 02-19-2008, 05:44 PM
