Thread: Lower intake manifold
Results 1 to 11 of 11
  1. #1 Lower intake manifold
    Nov 2008
    Chicago
    I got a SS intercooler that will be installed in the spring. Would a ZZP LIM be worth the extra cash?
  2. #2 Re: Lower intake manifold
    TDCRacing
    Guest
    NO!
  3. #3 Re: Lower intake manifold
    nope. waste of money. do it yourself with a dremel in 15 minutes.
    besides, i dont think you need to open up the LIM with an SSIC.
  4. #4 Re: Lower intake manifold
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Just as with any other intercooler, you don't HAVE to open up the blower and LIM, but you should to get the full effect. You don't have to buy one from ZZP, though, you can do it yourself.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Lower intake manifold
    Nov 2008
    Chicago
    I figured it would only be a few more bolts since I'm already taking everything else off (unless the injectors are in the LIM) but sweet deal. Thanks for the Info!
  6. #6 Re: Lower intake manifold
    TDCRacing
    Guest
    It's a cupple more bolt, And a cupple more bucks. Don't forget about the 50 aluminum intake manifold gaskets you have to buy
  7. #7 Re: Lower intake manifold
    Nov 2008
    Chicago
    The gaskets where on the back of my mind actually. While we're on the subject, does anyone know if the fuel lines need to be cut if i buy the injector spacers?
  8. #8 Re: Lower intake manifold
    TDCRacing
    Guest
    Nope you have plenty of slack.
  9. #9 Re: Lower intake manifold
    I live here. UR LOSN's Avatar
    Rockford, IL
    few more bolt to get it off, just make sure you go to the proper sequence when putting it back on.
  10. #10 Re: Lower intake manifold
    Nov 2008
    Chicago
    Quote Originally Posted by TDCRacing View Post
    I'll have plenty of slack right now or with the injector spacers?
    Am I more likely to have a leak extending the lines or using the injector spacers?
  11. #11 Re: Lower intake manifold
    TDCRacing
    Guest
    Nope you'll still be fine. There is a lot of slack in the stock lines. So whether you do fuel rails,spacers or what ever you'll be fine.
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Intake manifold :)
    By TheGreatGatsby in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-03-2009, 05:16 PM
  3. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
  4. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
  5. Intake manifold
    By joesforspeed in forum Turbo
    Last Post: 10-21-2008, 03:55 AM
