Thread: UPDATE: Coolant in Engine/I screwed up
Results 1 to 13 of 13
  1. #1 UPDATE: Coolant in Engine/I screwed up
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Hey guys,
    Well, for those of you who remember, I changed my LIM gasket and put everything back together, and now all I have to do is change the oil. The problem is I cant get my oil filler cap open and I cant seem to loosen the drain bolt on the oil pan, so is it possible that I can add extra oil to my engine (assuming i get the filler cap open) and then drive it ~2 miles to get the oil changed, or is it too risky?
    Secondly, I drained the antifreeze, but all I can seem to find is the orange dexcool. I heard that orange dexcool causes these gasket seals to wear out and that green dexcool is better. Any thoughts.
    Thirdly, and here is the 'I screwed up' part. I was reconnecting all the plugs, and I thought I had marked them all properly, but I have now ended up with one plug (3 pin/yellow colour) in front of the fuel rail, with no matching 2connector/receptacle. I'll try provide pictures tomorrow, but any idea as to what I missed?
    Finally, anyone know any GTP experts in California near Ventura?
    I'm almost done after a month, so its really frustrating to get stuck at this point, especially as its my first time doing such a major job!
    Cheers.
  2. #2 Re: UPDATE: Coolant in Engine/I screwed up
    Dec 2008
    OK, found the plug. Still dont know how I could've been so stupid!
  3. #3 Re: UPDATE: Coolant in Engine/I screwed up
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Well orange dexcool isn't really bad, it is made to fill holes. That's why it gunks up. Green stuff doesn't. As far as the antifreeze in your oil you should be fine driving it to get the oil changed. Just don't get into it. Why can't u get the oil pan plug out? Is it stripped? Use vise grips.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  4. #4 Re: UPDATE: Coolant in Engine/I screwed up
    I live here. UR LOSN's Avatar
    Rockford, IL
    2 miles isnt going to HURT it.
  5. #5 Re: UPDATE: Coolant in Engine/I screwed up
    Dec 2008
    Hey guys, I ended up draining the oil pan and changing the filter and oil, but when I started her up, there was still white smoke coming out the exhausts. I shut her off and checked the oil dipstick, and it had turned milky, - so there's probably more coolant in the engine. Is this normal after a LIM gasket change, or is something wrong again?
  6. #6 Re: UPDATE: Coolant in Engine/I screwed up
    Oklahoma
    Quote Originally Posted by t24moore View Post
    Where in the world did you come by this information at?
  7. #7 Re: UPDATE: Coolant in Engine/I screwed up
    Dec 2008
    Canada
    X2 I really want to know where and what it needs to "fill"? I had to flush like 4 times to get all the gunk out But I will let Syn handle this he has some very interesting pictures
  8. #8 Re: UPDATE: Coolant in Engine/I screwed up
    Dec 2008
    So I need to get rid of this orange dexcool?
  9. #9 Re: UPDATE: Coolant in Engine/I screwed up
    Dec 2008
    Should I try drop the oil pan? Maybe there's still some coolant left in it? I know I didn't do the new LIM install wrong, and my head gaskets were fine, so I dont really know what else to do. Anyone with any advice?
  10. #10 Re: UPDATE: Coolant in Engine/I screwed up
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    ... You didn't drain you're oil after a LIM replacement?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  11. #11 Re: UPDATE: Coolant in Engine/I screwed up
    Charles City, IA
    Did you RVT the corners? Did you replace the head gaskets after you checked them (OEM ones can not be reused)? The only thing I can say if both of those are a yes drain the oil one more time and see if it is still milky. If it is you will just have to tear it back down and check everything again.
    SMGPFC Two Nipple General
  12. #12 Re: UPDATE: Coolant in Engine/I screwed up
    Dec 2008
    Freebeer: I did drain the oil after the LIM gasket change, and added new oil+filter, but after restarting it, the car still ran rough and after a couple of minutes idling I checked the oil dipstick and it had turned milky again.
    I'm sorry 01GTP, I'm not really sure what RVT the corners means, unless you mean use the gasket sealant. I did that. I replaced the head gaskets.
    I talked to a mechanic who said that sometimes in the oil pan there is still a little oil left no matter how much you drain out, and that maybe some of the old coolant-oil was in there and got sucked back into the engine or something.
  13. #13 Re: UPDATE: Coolant in Engine/I screwed up
    Charles City, IA
    I was talking about putting some type of sealent where the rubber sides meet the actual lim gaskets. Just try changing the oil again and see how it looks.
  1. Engine Coolant Temp Fluctuating
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-29-2013, 04:33 PM
  2. UPDATE: Coolant in Engine (Warning 7 100KB pics)
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2009, 08:11 AM
  3. Im sooo screwed!
    Last Post: 11-27-2008, 01:00 PM
  4. Screwed?
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 11-25-2008, 11:21 PM
  5. Engine Coolant Question
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 03:03 PM
