My 04 GTP comp G has been running very rich recently to the point I stopped driving it so I wouldn't mess up the Cat. I don't know if they are related or if it is coincidence but the throttle position sensor went south at about the same time causing a lower power warning. I replaced the pedal assembly and the error codes are gone but ever since I've been extremely rich.
I needed to replace the lower intake due to a slow coolant leak so while I was doing that I replaced the upper O2, MAP, BAR, Injectors and MAF along with new spark plugs/wires since most of that needed to come out anyway and most of them were original. But none of those were the cause. The only mods are a CAI, front power log and a ZZP 3" downpipe that have been on the car for years.
STFT and LTFT are in the -20s most of the time. There doesn't seem to be an exhaust leak anywhere. I tried finding what the fuel pressure should be for the 04 with the return less system but I have found a lot of conflicting numbers during searches from 42-50psi? So if someone has a shop manual with those numbers I'd appreciate it. - Thanks
