#1
Empty bolt hole leaking oil. What goes there?
Re: Empty bolt hole leaking oil. What goes there?
forgot to add it is a 97 Gtp. This is a replacement crate motor that was installed in 2004. The shop working on it is the shop that swapped original motor for this one.
#3
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
#4
GXP Level Member
03-20-2021
iirc a 10x 1.5 thread "plug" boilt goes in there. that boss is only used on the G/H bodies with the earlier cast iron front engine mount that makes it such a PITA to replace G/H body belts.
get a short (less than 20mm UHL) m10 x 1.5 bolt and toss it in there. allen head may be easier to get to as the original bolt/pluig is a torx drive
~James~ Psychotic Gearhead
#5
Thanks for the pic, thats great. I was thinking, that isnt where one of the engine hoist things attach to is it? I have mine off the motor.
#6
03-23-2021
Nope..those go up front driver side off exhaust/head and rear passenger side. That hole might have a loose ground wire with a loop hole connector nearby. If so.. ground it with that bolt when you put it in.
#7
Hi guys,
thanks for all the info, the prob im having is that i have zzp's intercooler and when a bolt is put in that hole the engine builds a bunch of pressure according to my mechanic. He doesn't like that.
This is a replacement crate motor installed in 04, this bolt hole has never had a bolt in it. It weeps oil when nothing is there, now i know why i always smelled oil when i used my ac or heater.
Was I supposed to get a breather oil cap when i got the ic back in 04? No one ever said that was necessary. We are not using the zzp gasket at the moment, i see on their site they say that you cannot cut a stock gasket to work right.
Do i need to get the zzp gasket? I had it when i installed the ic and it has been on since 04 with no prob. I forgot about it until the other day when this bolt/pressure problem cropped up.
#8
03-23-2021
heres the fix for the lame zzp ic with non working pcv on one side.
How to get PCV to work instead of valve cover breather!
#9
Thanks again guys, really helps me out.
#10
So looking at the thread it looks like i need to drill out that brass plug in my tb and drill a hole in my oil filler cap and run a vacuum line between them? or run a breather oil filler cap.
Those are my options? I have a early 97 gtp built in aug of 96 if that helps.
I look at zzp's breather and they say you need to to a pcm programming change if you run the breather. but, this bolt hole has been open since i did the ic and a custom tune by paul back in probably 05ish. Do i really need a new tune, or change on the pcm to run a breather, seems this open bolt hole has been breathing in the front of the motor for 17yrs just fine. I am in socal so i have been passing smog tests fine.
I don't have anyone that can do programming around here. so, i shouldn't run the breather and should do the drilling and line?
#11
03-23-2021
not knowing your tune, but sealing off that port and running a vac line to the tb is the only way to keep un metered air from getting into the engine. if it was tuned with the hole open, maybe a breather would do. were talking a in car tune? or a canned tune?
#12
paul from prj performance came out to so cal back in 05 i think it was and tuned a bunch of the gp's here. He custom tuned it then. The sc was put on before then and there was no mention that i can recall of breathers. but, i wonder if the guy that i helped do it pulled the plug out of the hole then. I dont remember him saying anything or doing it but obv it was done and it was a long time ago.
i doubt it came that way from the factory. and if it did, it just so happened to help me when i put a ic on the engine that needs a breather somewhere. maybe the guy that did the ic install didnt know the hole would weep oil.
#13
plus the shop thats doing the work now, is the shop that installed the new motor back in 04. they caught this now, i doubt they wouldn't have then.
#14
the bolt hole oozing oil that is, because no bolt there
#15
03-23-2021
id run the vac line, see if it runs better maybe. if it dont its easily reversed.
#16
vac line, wouldn't that mean i need to drill the tb plug?
#17
03-23-2021
#18
wouldnt it be easier to not drill and pop on a breather oil cap?
#19
or is it that the vac line is a more professional way of doing it?
#20
oh i reread your comments, un metered air. since the car has been getting unmetered air from the bolt hole for so long and was tuned that way, wouldn't it be better to have non metered air going in?
