Thread: 3.0" Pulley - Bigger Injectors Necessary?
Results 1 to 6 of 6
  1. #1 3.0" Pulley - Bigger Injectors Necessary?
    Feb 2019
    ON
    Hey guys, Ive read conflicting articles about upgrading your injectors for a 3.0" pulley. Some say its necessary, others say you can get away with stock depending on the tune.
    Just wondering if anyone has any experience with it.
    Cheers
  2. #2 Re: 3.0" Pulley - Bigger Injectors Necessary?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    You will likely go static on stock injectors at WOT on a 3.0 pulley. Upgrade to 42.5#, retune IFR and tweak the MAF table to stabilize the trims.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: 3.0" Pulley - Bigger Injectors Necessary?
    will need 42's at min. but as long as your buying em, get 60's i maxed out 42's on a 3.0 gen 5 with a fsic.
  4. #4 Re: 3.0" Pulley - Bigger Injectors Necessary?
    Feb 2019
    ON
    Thanks for the input guys. I found a set of 42s for $200. Seems like a pretty good deal. Figured I try those out. The cars in storage until spring so if a set of 60s come up over the winter at a decent price I'll switch em out.
    Guess I'll pull the trigger on them. You guys rock
  5. #5 Re: 3.0" Pulley - Bigger Injectors Necessary?
    May 2008
    Schuyler, NE
    I ran stock injectors on a 3.0 for quite a while without problems. If you have the money, I'd get bigger injectors though.
  6. #6 Re: 3.0" Pulley - Bigger Injectors Necessary?
    Feb 2019
    ON
    I pulled the trigger on the injectors. For $200 I figured why not.
    My goal was to run a 3.2" and call it quits but then a guy reached out after almost a year and said he had a 3.0" that he didn't need.
    So now it's just a waiting game to replace the tranny lol
  1. Looking for 3.25" MPS pulley and 60# injectors
    By digitaloutsider in forum Wanted To Buy - Parts
    Last Post: 03-16-2017, 10:41 AM
  2. SALE ZZP Bosch 42.5lb injectors,ZZP 3.0 pulley, ZZP 1" injector spacers
    By Tonkin2000GT in forum For Sale - Parts
    Last Post: 02-20-2017, 04:10 PM
  3. Replies: 22
    Last Post: 06-16-2016, 02:52 PM
  4. When to get bigger fuel injectors
    By RideWithPride in forum General Tech Discussion
    Last Post: 08-08-2012, 07:49 AM
  5. when to get bigger fuel injectors?
    By pontiacmanj2 in forum General Grand Prix Discussion
    Last Post: 05-31-2012, 02:21 AM
