Thread: What should i do while my engine is apart?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: What should i do while my engine is apart?
    3.0 and a gen 5 will whine just fine. its a tuning game, more boost less timing or less boost more timing. one will work better. just need to play around and see whats faster.
  2. #22 Re: What should i do while my engine is apart?
    May 2008
    Schuyler, NE
    Quote Originally Posted by 04lss View Post
    I want the noise.
    A 2.6 versus a 3.0 isn't going to make too much of a difference. My car is setup differently, that's why it whines so much.
  3. #23 Re: What should i do while my engine is apart?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Well i have the 2.9 now. wines pretty good. I plan to weld off the silencer ports too. I am not installing a pulley right away. So chances are ill slap it with 20* of timing or more on the 2.9 with the Meth and the cam. Currently im seeing boost at 14PSI at the top of 2nd. Im expecting that to nose dive with the ported heads, headers, cam, and catback.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  4. #24 Re: What should i do while my engine is apart?
    i was at 13 psi on a 2.8 with ported heads and rockers, with a na bottom end too.
    so im sure you'll drop a few psi with heads and that huge ass cam.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 2000 Grand Prix with series 1 Engine, Weirdest engine problem ever!
    By ElectricBlake in forum Introductions/Noob Questions
    Last Post: 01-19-2016, 12:15 AM
  3. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  4. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
