Thread: Valve tapping
Results 1 to 7 of 7
  1. #1 Valve tapping
    Oct 2019
    MD
    I took my car to a summit point raceway while running stock weight oil and my car developed a pretty loud valve tapping. Ended up putting heavier weight oil in and running 10+ laps with no power issue but I'm wondering if it's potential spring fatigue making my valves make a tapping noise.
  2. #2 Re: Valve tapping
    May 2008
    Schuyler, NE
    I would guess it's a lifter.
  3. #3 Re: Valve tapping
    St. Louis
    I would say we need more info on what year, any mods to it, mileage, etc. Taking a car to a track and beating on it and then getting a loud tapping noise is usually not good.
  4. #4 Re: Valve tapping
    Oct 2019
    MD
    It's a 2000 Pontiac Grand Prix with the L67 motor, I have a 3.4 inch pully, headers, straight pipe, colder plugs and that's really it. Coolent temps got up to 210 before I'd go easy on it. I have a video of the tapping should I post it on YouTube and post the link here ?
  5. #5 Re: Valve tapping
    May 2008
    Schuyler, NE
    You probably spun a rod bearing.
  6. #6 Re: Valve tapping
    Oct 2019
    MD
    Update: I've replaced the rockers, push rods, springs, retainers, valve covers and the gasket for it, but the sound is the same so I'm probably looking at a spun baring but it just doesn't sound loud enough
  7. #7 Re: Valve tapping
    Oct 2014
    portland oregon
    GTPpower mentioned a lifter at the very beginning.
    Did you check those while you had it blown apart?
    You probably didn't take the blower and lim off but, may have to now.
    I would agree with you that there is a difference between a tapping and a knocking.
    Did you put stiffer springs in while you were in there?
    Sent from my SM-N920V using Tapatalk
  1. Tapping a TPS and RPM signal
    By Dailordasailor in forum PCM Tuning
    Last Post: 10-09-2012, 06:35 PM
  2. WTH is this tapping noise
    By dagger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2011, 10:53 AM
  3. tapping in engine
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2010, 11:13 PM
  4. Tapping power from Amp.
    By m0ng00se in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 07:57 AM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
