Thread: Can a bad MAP sensor cause the engine to run lean?
Results 1 to 14 of 14
  1. #1 Can a bad MAP sensor cause the engine to run lean?
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    I have been battling a lean code for a while now. It is very strange with how it is behaving. I have checked for vacuum and exhaust leaks. The fuel pressure is good and I have a new filter. Fuel trims do not drop if I raise the RPM off of idle. The CEL sets the p0171 every so often. Seems to get set quicker if I am using the A/C? My question is would a faulty map sensor cause the ECU to thing the engine is at a different load and command the wrong amount of fuel and timing that in turn would create a lean exhaust mixture?
    2004 GTP
  2. #2 Re: Can a bad MAP sensor cause the engine to run lean?
    May 2008
    Schuyler, NE
    I doubt it. Try unplugging the maf and see if anything changes.
  3. #3 Re: Can a bad MAP sensor cause the engine to run lean?
    Sep 2018
    NC
    I tried that and the engine ran okay just extremely lean my wide band was maxed out at 20
  4. #4 Re: Can a bad MAP sensor cause the engine to run lean?
    May 2008
    Schuyler, NE
    Ok, what happens if the maf is plugged in and you unplug the map?
  5. #5 Re: Can a bad MAP sensor cause the engine to run lean?
    Sep 2018
    NC
    The car continues to run. If I start the car with the MAF unplugged and plug it back in while running the engine will stall
  6. #6 Re: Can a bad MAP sensor cause the engine to run lean?
    May 2008
    Schuyler, NE
    Do you have a scanner that can read maf output?
  7. #7 Re: Can a bad MAP sensor cause the engine to run lean?
    This is going to sound odd, it's experience talking though.
    Look at your battery cables where they go into the ends by the battery and the other ends of them. Do you see the insulation pulled back slightly and greenish color instead of nice clean copper? If so.. consider replacing them.
    I chased P0171, replaced the egr tube (they crack at intake manifold), checked grounds in the harness etc etc etc. Then had guy who had been a GM mechanic for years tell me to replace the cables. Since I had done everything else, I did. Fixed the issue and when I opened up the insulation on the old ones I found a decent amount of corrosion which messes with the voltage of the vehicle.
  8. #8 Re: Can a bad MAP sensor cause the engine to run lean?
    Sep 2018
    NC
    Thats something I will have to check in the morning. Come to think of it sometimes when sitting idle with the door open I notice my dome lights would fluctuate and I didnt think anything of it. Just thinking it was the voltage being regulated by the alternator.
  9. #9 Re: Can a bad MAP sensor cause the engine to run lean?
    Sep 2018
    NC
    I reflashed my ecu with a modified tune and the problem completely went away I didnt even adjust the fueling in the areas that was previously lean. Now im getting a weird P0403 code every time the car starts up. I monitor for misfires after startup and there is none. I tried another reflash to see if that would do anything and it didnt change anything im confused on why I would only get the misfire code for cylinder 3 on startup and see no symptoms.
  10. #10 Re: Can a bad MAP sensor cause the engine to run lean?
    Might need a crank relearn after the flash. Also the flash will reset all your fuel trims and you need a certain amount of drive cycles for that to log etc if it's going to come back
  11. #11 Re: Can a bad MAP sensor cause the engine to run lean?
    Sep 2018
    NC
    Ive never done a crank relearn I dont really know what a symptom of needing to do one is.
    As for the fuel trims they have been stable and no longer lean like they were before the reflash
  12. #12 Re: Can a bad MAP sensor cause the engine to run lean?
    Symptoms inlcude odd stuff that you can't explain.
    Like getting a misfire code after doing nothing but a flash.
    Odd misfires that you can't determine, no matter the amount of testing etc.
    I've had a few that after a motor/trans swap etc that upon startup run like crap and after checking things over you are left with no leads. Crank learn is like waving a magic wand and all woes are fixed. The issue is basically that the pcm doesn't learn the exact crank position and therefore is not tossing the spark etc at the correct times.
    BrandonHall recently had some odd behavior from his Regal and no matter what he tried nothing quite fixed it. Crank learn and it's a happy car once again.
  13. #13 Re: Can a bad MAP sensor cause the engine to run lean?
    Sep 2018
    NC
    Ill have to try that. Ive never done one and there has been many many flashes and a lot of things I just cant find the cause for that would come and go.
  14. #14 Re: Can a bad MAP sensor cause the engine to run lean?
    Jun 2021
    Bad EGR or bad wire connection between the EGR and pcm .. if the EGR isn't closing all the way the motor will run lean
  1. WTB Engine Temp sensor
    By chris99gtp in forum Wanted To Buy - Parts
    Last Post: 09-02-2015, 09:08 PM
  2. engine coolant temp sensor
    By Dee23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2015, 06:28 PM
  3. Check Engine Light - Lean
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 09-20-2011, 03:57 PM
  4. KR sensor,running lean and oil psi
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2011, 09:40 PM
  5. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
