GTP Level Member
06-24-2020
Hello all,
I just converted my 07 supercharged Grand Prix to e85. I installed the pump and 60# injectors. Problem is very rough starts and really rough idle. It drives perfect and has nice power. I don’t notice the issue under driving acceleration. It is 70* here so not really a cold start. I’m not sure what’s going on. Does anyone have any suggestions on what is causing this????
2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
#2
Re: E85 very rough idle.
Hate to point out the obvious, but this screams tune issue.
#3
Donating Users
06-24-2020
How did you tune for e85? I'm guessing you just need more fuel but can't say without seeing logs. There are tables for startup that you can add fuel. We'll, yours probably has more tweakability than my 01. I had to really richen it up to get it to start right up, even cold starts on warm days. U hav wideband?
Top Swapped 01 Imp
#4
GTP Level Member
06-24-2020
I figured it was a tune issue.
I set stoich to 9.67, IFR changed for injectors and aslo open loop vs coolant temp. here is a link of my tune. Any help is appreciated.
Transfer - Dropbox
#5
Donating Users
06-24-2020
That might be your problem. I think changing stoiche to 9.67 is not the best way on these pcms. It effects other tables as well that you might have to change. Best way for me was basically only changing a table for injectors, I think it's called offset? From 1.00 to 1.30 after changing IFR, then all u have to do is tweak the MAF table. I'll have to double check when I get home.
Edit: I think it's injector scale. Btw, there's a really good e85 tuning guide on this site. Think it's a sticky.
Top Swapped 01 Imp
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
#6
GTP Level Member
06-24-2020
Thanks Bandook! I will start over again and follow that way. Thanks for the suggestion. I will let you know how it turns out.
#7
GTP Level Member
06-24-2020
question, in the "Defacto Guide" it says only to change the injector skew(cylinder gain). Is this correct. Should I also adjust the IFR? 33/63= 0.5238. do I multiply positive (x 1.5238) or negative (-1.5238) I am having a brain fart. Thanks for the help. i probably should have posted this in the tuning forum. :-/
#8
Donating Users
06-24-2020
Yeah, gain... couldn't remember. For IFR, I can't remember exactly how I got mine. I read so much trying to figure out the best values to use. But since there are no exact numbers to be found for these injectors, you basically multiply your IFR table the percentage that the 60's are larger than what u have. Then you can tweak the MAF table from there. I really don't think it has to be perfect. Don't worry about the other injector tables unless you know how to calculate those. If going from 33 to 63, is basically 48% bigger. So maybe start by multiplying by 1.48xx. If your skew is 1.30 or 1.28 or whatever and you only changed the IFR and your wideband shows terribly rich or lean, then I would multiply your IFR by 5% until it looks closer to stoich, then start tuning MAF.
That's just my way, not saying it's the best. Everyone has their own way on this platform, but I will link you to a really good guide for tuning real quick. I can now take a gnarly tune and get it real close with just a few edits, with this guide.
Top Swapped 01 Imp
#9
Donating Users
06-24-2020
Here is the link. I see you are already on the hptuner forum. Good luck getting much help there, lol. If you don't have a small block you won't get much attention. But this guide is the simplest and quickest I've found and is very easy to follow. If you have any questions just hit me up.
Top Swapped 01 Imp
#10
GTP Level Member
06-24-2020
Thanks a ton for your help. I took your advise and changed those two parameters. It worked great. I changed the gain to 1.225 and multiplied the IFR by 1.5238 (33/63) the trims were within 4% of zero. so pretty much dead on.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#11
GTP Level Member
06-24-2020
bandook
HPT forums suck!!!! Zero help there and outdated information. Once in a while 5FDP pops in and helps.
#12
Donating Users
06-24-2020
Nice! Time to drop that pulley! You could easily run a 3, if not a 2.8.
Top Swapped 01 Imp
#13
GTP Level Member
06-26-2020
Trims aren’t as good as they should be. I’m trying to get WOT fueling down. I’m getting 2-4* of knock WOT. All else is good. The AFR Wot is around 6.2. I’ve read it should be 7.7. Maybe it’s too rich causing knock. Wot timing is between 20-24*.
#14
GTP Level Member
06-26-2020
The Trims on some cells wot is +3 but the AFR is 6.2.
#15
Donating Users
06-26-2020
I dunno anything about going by E85 stoich values. Did you adjust the other tables to same stoich? But I think you should take your timing way down before and work on your fuel, then slowly bring timing in. If you use that guide i linked i bet you get your trims locked in at 0 wot. But yeah, being too rich can cause knock. You don't want to enter PE and be adding or subtracting fuel.
Top Swapped 01 Imp
#16
GTP Level Member
06-27-2020
I got it all good now. I didn’t use stoich. I used the method you mentioned. I used my wide band for 7k plus ignoring what the trims said for that range. Everything is good now. Not much knock now.
#17
Donating Users
06-27-2020
Nice. Are you going to pulley down now?
Top Swapped 01 Imp
#18
06-27-2020
the stock fuel pump will lean out if you go smaller than a 3.2 or so. I bought an ethanol content tester so I knew what blend the gas station was selling at the time. you don't have to check it every time, but it's handy information to dial in the fuel. I used the cylinder gain method too, it was really simple.
#19
GTP Level Member
06-30-2020
Hey Sgt.
I have the AEM ethanol pump installed. I have a content tester. So far it’s running between 90-95 ethanol. Speedway gas.
Thanks bro.
