Thread: Spark plugs
Results 1 to 20 of 31
  1. #1 Spark plugs
    Oct 2019
    Ridgecrest ca
    Alright guys and gals, delving further in to the what is my ecm/what has been done to this car.
    I’m doing the plugs before work today. I bought the tr6 NGK plugs, I love NGK, I’ve ran them in almost all of my vehicles.
    The plug I just pulled out is a delco ITR4A15. Iridium yes, but, if memory serves correct, that is colder than the NGK tr6, correct?
    Sooner I find out the better as I’m about to pull them all. They look eh, definitely been in the car a long time.
    As of now, looking at the engine, the absolute only mod is the air intake from k&n, stock pulley and all, no exhaust mods, not even the u-bend delete.
    Any thoughts?
  2. #2 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    I might have been wrong. I don’t think it’s stock manifolds. Just old. And is that not an egr block off plate?
    Also, here’s the front one.
  3. #3 Re: Spark plugs
    GTP Level Member
    Oct 2014
    Not sure if the tr6’d are platinum but these engines hate platinum. Use iridium or copper.
    I am not sure on the heat ranges.
  4. Likes Gingershrek liked this post
  5. #4 Re: Spark plugs
    The EGR is on the other side, if it's there. It connects to the intake manifold/supercharger just behind the throttle body and the other hose goes down to the exhaust manifold at the number 2 cylinder.
    The block off plate could be for something dealing with a California emissions related item but the picture isn't that great.
  6. Likes Gingershrek liked this post
  7. #5 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Yeah. Sorry. Let me run out and take a pic.
  8. #6 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Here’s a better one, also, found this little guy on the cowl under the hood.
  9. #7 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    That’s what I figured. Maybe air injection? But then wouldn’t the front cylinders have the same?
    I’m in California and she passed out stupid smog check. But then again, so did my catless speed density running on E85 with 2000cc injectors STi. Lol.
  10. #8 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    And I will also say, it was like a gorilla tightened the plugs in there! I actually had to add a wrench to the ratchet handle to break them loose, but once that was done, they spun out smooth and new ones when in with no hiccups. Honestly the easiest plug job I’ve done. Then again, it’s either been a Subaru or lifted truck I’ve been working on. Once you’ve done plugs on an ej255 without jacking the motor, everything’s easy. Haha.
  11. #9 Re: Spark plugs
    The air pump would be down by the airbox with a hose going back to the exhaust before the cat.
    I forget what else the CA emissions had, likely another smog type system.
  12. #10 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Well hell. I’d like to know what it is. Unfortunately it’s not part of any exhaust manifold I have found for OE replacement. It’s definitely a block off plate that feeds in to the head.
    Also, on the air pump, every one I have seen is belt driven. Is this one not. I guess I’m too old school?
  13. #11 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Oh, also, the car came from a dealer back east. So maybe it’s a not installed smog part?
  14. #12 Re: Spark plugs
    ca cars are sold through the country brand new. get us some better pics of that block off and the rail its on.
  15. #13 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    I’ll try on my lunch. At work and we have cameras everywhere.
  16. #14 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Screw it, running out there real fast. Give me 5.
  17. #15 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Here’s some more. I did notice as well, after switching to the tr6 plugs, when it fires up, there’s the sound of a rough start/very small miss for a sec. compared to the delco plugs which would literally bump of the key fast start up. Almost instantaneous.
  18. #16 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    I said head earlier, meant manifold. Was getting ready for work so I was rushed.
  19. #17 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    Quote Originally Posted by markpa View Post
    I’m so sorry I missed your post!!! They are the recommended “most sold” plug that zzp stocks. The price was great, that’s why I used them. The same plug at our local Autozone is almost $2 more per plug. Ridiculous, it’s typical California bs.
  20. #18 Re: Spark plugs
    thats part of the ca smog pump BS. its been deleted clearly. or some bs someone installed on it. heat shields are all missing too.
  21. #19 Re: Spark plugs
    Oct 2019
    Ridgecrest ca
    That is true. Are these OEM manifolds or some eBay header stuff?
  22. #20 Re: Spark plugs
    they aint headers thats for sure lol
  1. Spark Plugs on '04
    By 04GT2 in forum General Tech Discussion
    Last Post: 08-10-2016, 12:34 PM
  2. Spark plugs!!!
    By tlawnewtograndprix in forum General Tech Discussion
    Last Post: 03-28-2013, 12:29 AM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. spark plugs...
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2010, 09:40 PM
  5. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
