Thread: HP Tuner with Pro link and AEM WB (30-4110)
Results 1 to 5 of 5
  1. #1 HP Tuner with Pro link and AEM WB (30-4110)
    Jul 2012
    Bloomington, IL
    Does anyone here use the Hp Tuners Pro link to connect the AEM WB model 30-4110? I've researched the wiring for the two, and cannot find anything for this model AEM.
    It looks like the white wire of the AEM (5v output) would connect to the red wire on the pro-link (Analog 1), but I'm not positive.
    2005 GTP - Headers, 3" DP, resonator, and catback, CAI, 605 plugs *Sold*
    2016 WRX Premium - Stage 2 E30
  2. #2 Re: HP Tuner with Pro link and AEM WB (30-4110)
    pretty sure you got it right. i use the 5v wire to my egr and import it into hpt that way.
    you do still have to set it up in the scanner. the maths are pre done for you so its bit easier then through the egr plug.
  3. #3 Re: HP Tuner with Pro link and AEM WB (30-4110)
    Jul 2012
    Bloomington, IL
    So where does everyone run the wideband sensor cable? I didn't want to drill, but it doesn't look like I have a choice. '05 GTP
  4. #4 Re: HP Tuner with Pro link and AEM WB (30-4110)
    i got 99% of all my wires ran through the shift cable grommet. you need to pull the pass side carpet down so you can get your hand up to about dead center to the fire wall. i used a long screw driver with a pull wire taped on the end of it, push it through, find it on the other side . then you can tape the wb cable to the pull wire and pull the wb cable through.
  5. #5 Re: HP Tuner with Pro link and AEM WB (30-4110)
    Jul 2012
    Bloomington, IL
    Damn. That spot is golden...Thanks for that. I took the thick rubber piece out, and there's all kinds of room the to make a spot in the rubber grommet. I actually used some electrical wiring to shove thru there and pull it up in the engine bay, tape the wideband cable to it, and pulled it back thru. Now I'm thinking a boost gauge is in order also.
  1. 97-03 DHP or HP tuner, off board tuner and top 1/2 L36 parts
    By Scottydoggs in forum For Sale - Parts
    Last Post: 10-25-2018, 07:46 PM
  2. Any have the DHP power tuner program or a link?
    By oldsman105 in forum PCM Tuning
    Last Post: 09-26-2015, 10:01 PM
  3. Replies: 1
    Last Post: 06-13-2012, 05:46 PM
