Thread: Planning my mods, need advice
Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 272
  1. #61 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by ItHurtz View Post
    Sc is going to limit the turbos power making capability eventually, make more without it. Pt61 there really is no lag on these motors, she will start spooling (slowly) just accelerating in the same gear.Should be any worse with the z3. WOT when I had the l67 it took about 2 seconds from a dead stop to go from no boost to the tires ripping through the intersection, and from there on your butthole was puckering.
    Turbo, e85 with 80's you would sell all your cars because there is no comparison to this.
    I get what youre saying, but 2 seconds is a long time to wait for power, especially since i drive this thing to work and through downtown. I want torque when i want it, even if i dont need a tone.
    Also, no chance im driving a Buick at VIR, or summit point. No matter how much power it makes, i wouldnt trust a Wbody at 120 in a turn.... So the GTI stays
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #62 Re: Planning my mods, need advice
    Antioch, IL
    The rumor is the rotors and if intercooled are restrictions, thus why big builds are never twin charged.
    2800rpm a pt61 is singing loud and clear.
    Ill take 2 second lag vs a m90, the power between the 2 isnt even comparable. That butthole pucker is so awesome
    2009 Challenger SRT8
    Expert at being gay.
  3. #63 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    You may be able to get it to work with a tune on some cars. I'm not real sure if that's possible though.
    I would add a boost switch that will trigger the bypass.
  4. #64 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    I'd recommend not listening to these rumors.
    Those two seconds gives you a nice taillight view of a good running m90 build.
  5. #65 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I guess it would read boost from the charge pipe, and once that hit a certain PSI, trigger the bypass to open?
  6. #66 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Honestly, Ill take a reduction in overall power for the satisfaction of instant power. As long as i can make close to 400 im happy. Another thing too, is that there is nothing lost by twincharging. If i don't like it, i can just remove the rotors slap the end plate on and go from there.
  7. #67 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Yup!
  8. #68 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    I would prefer the lag would make takoffs easier and not spin the wheels so much my dsm had like 250 to the wheels and had like a 2 sec lag you couldn't spin the tires in the rain if you but once the lag was gone thing pulled you hard and still no tire spin it was AWD also haha. I remember this ricer kid I grew up with kept wanting me to do a burnout and I would always say I cant and people who didn't know cars didn't believe me because the thing took off so quick then he would tell me he could make it do a burn out I was like HA good luck itd be easier doing it with my dads focus base model
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  9. #69 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Im thkning about ordering the turbo kit on friday, since the plan is to twin charge, is it possible to just unplug the bypas module until i can figure out how to rig everything up for the twin charging? That would keep me from having to buy the m90 blockoff plate.
  10. #70 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    gtppower never really answered the question of how much horsepower it took to turn the m90. I don't know for sure, but I know it's more than the 1-2 he said.
  11. #71 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Quote Originally Posted by SgtMarshal View Post
    How much more of a detailed answer do you want than 1-2?
    Eaton claims at cruise, the m90 uses about 1/2 a hp.
  12. #72 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Quote Originally Posted by 04lss View Post
    I don't think unplugging it will do anything.
  13. #73 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Quote Originally Posted by tzerilli View Post
    You didn't have any problems with spinning because you only had 250whp and AWD.
  14. #74 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    here is my "rough" plan
    Order the z3 kit.
    Switch back to pump gas
    Install it with the supercharger intact but unplugging the bypass so that it remains open
    Set the Turbo to whatever boost stock injectors will tolerate
    See if i can live with the lag, if not work on twincharging, if so, yank the roots out
    Step 2:
    80lb injectors e85, fuel pump Big boy boost levels
    step 2.5 start building a trans.
  15. #75 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I supposed i could just remove it
  16. #76 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    on the topic of twin charging, I imagine i could use something like the pump controller for the meth system. It would trigger at x psi on the charge pipe, which should be independent of the boost the SC is making since the charge pipe is before the SC.
    Once it triggers ... What does it do? I thought the natural state for the bypass valve was open, and applying current to it, or boost is what closed it.
  17. #77 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Vaccum is suppose, not boost.
  18. #78 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    That should work.
    The bypass is open during normal operation. As you mash the gas, the bypass closes. The m90 can't produce boost until the bypass closes, since it doesn't compress the air until it's in the LIM.
  19. #79 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Order the z3 kit.
    Step 2:
    You can't build a kit yourself, can you?
  20. #80 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I suppose i could, but buying the kit takes the guess work out, and i really like the Oiling solution that pulls from the sender. I think the standalone solutions all require taping the tank.
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
