Thread: Transmission fluid in power steering
Results 1 to 2 of 2
  1. #1 Transmission fluid in power steering
    Jan 2013
    Texas
    Had a friend take my 02 gtp into a shop to change out the steering rack last month, and i noticed the steering was stiffer. Found out that there ATF in the P/S resv. Is ATF a sub for power steering fluid?
  2. #2 Re: Transmission fluid in power steering
    Jul 2017
    macomb mi
    yes it can be if you go to a oil change place that does them a lot of times they will use ATF for both trans missions and power steering they used ATF in my power steering when they flushed mine out about a year ago really no noticeable difference except less groaning when turning the wheel all the way to one side
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. Power steering fluid
    By themantis in forum General Grand Prix Discussion
    Last Post: 04-22-2016, 09:34 AM
  2. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  3. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  4. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
