Thread: 04 GTP - PCV causing rich LTFT?
Results 1 to 2 of 2
  1. #1 04 GTP - PCV causing rich LTFT?
    SE Level Member Moozery's Avatar
    Apr 2016
    Ontario
    Owned my 04 GTP for 2 years now and I think I may have finally figured out why my LTFT's have been very rich (-16 to -25/maxed).
    If I disconnect and block the PCV hose that goes from behind the MAF to the top of the SC, my idle trims immediately become perfect. (I've still been making sure the PCV has air)
    I'm aware that this hose pulls air into the PCV system post-MAF, which will be "robbing" a little bit of air from the calculated A/F, but I feel that this hose causing this level of rich LTFT is a sign that something isn't right.
    - There doesn't seem to be any noticeable pressure/vacuum from the oil fill hole, and the engine doesn't behave any different when it has been removed while running.
    - PCV valve is only about a year old
    - LIM gaskets are changed
    - 100k miles, stock pulley, vacuum is good
    - Swapping MAF made no difference
    - Doesnt consume oil
    What do you guys think of this? Hopefully I'm not sounding too confusing.
    Pre-Production 2004 GP GTP Comp G / 91,000mi / TransGo Shift Kit, Spectre Open Cone, 180 Tstat, AL605's, ZZP 3" catted DP, ZZP front PLog, Intense PCM, GMPP Sway Bar
    Access Old "How-To" Links
  2. #2 Re: 04 GTP - PCV causing rich LTFT?
    HUDSON
    Was the o-ring still in good condition when the PCV valve was changed.
  1. ltft causing lean idle
    By jrb1027 in forum PCM Tuning
    Last Post: 09-15-2017, 07:17 PM
  2. Ltft show rich but wideband and stft say otherwise
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2014, 10:28 AM
  3. Cold thermostat causing rich condition?
    By EastBayGPSE in forum General Tech Discussion
    Last Post: 03-03-2014, 05:02 PM
  4. Rich LTFT
    By Dschroeter63 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2013, 09:32 PM
  5. why do my ltft's go rich when hot?
    By Lawngoose in forum PCM Tuning
    Last Post: 08-12-2010, 04:42 PM
