Thread: engine swap
Results 1 to 6 of 6
  1. #1 engine swap
    SE Level Member fever42's Avatar
    May 2008
    Mobile, Al
    i just purchased a complete 3800 sc from a 06 grand prix, putting in a 05 montee\ carlo do i need the 06 pcm or can i use my 05 i will be useing the 05 tb not the drive by wire on what elae will i need to change Thanks
  2. #2 Re: engine swap
    you need the montie pcm tuned to run the sc engine. unless it came with a l67.
    and you need a tb adapter to run your old tb. and might have to change any sensors that dont plug in as they should.
  3. #3 Re: engine swap
    May 2008
    Mobile, Al
    Thanks It was a L67 in monte,
  4. #4 Re: engine swap
    if it was a l67, you dont need a tune then. cant hurt, but you dont need it.
    you'll need to use most of the sensors off the top of the l67. map, evap, and the old fuel rail.
  5. #5 Re: engine swap
    You can actually use the new evap if you'd like. Just remove some loom and black tape to bring the evap wiring behind the TB on the charger where the new evap is located. The map sensors are simply a different plug and the connectors can be swapped over as the wiring is all the same color, match each color wire and they will swap right on as well.
  6. #6 Re: engine swap
    May 2008
    Mobile, Al
    Thanks great info
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
