#1
Nitrous wet kit install and activation
Wondering who's got a nitrous kit and how are they activating it. Running it on a TPS switch and just going all in at wot or boost reference progressive controller and ramping it in? Button activated? Also where is the fuel supply coming from? Using a stand alone tank and pump? Thanks!
#2
Re: Nitrous wet kit install and activation
GXP Level Member
10-17-2018
The zex kit I ran used a TPS switch. I set up a second stage on a progressive controller, but never used it.
For the fuel supply, I just used the test port location on the fuel rail. Later, I went to a standalone system.
#3
Where you spraying in 1st or just 2nd and 3rd? What kind of pump were you running when it was tapped into the rail? Also what type of fuel?
#4
GXP Level Member
10-17-2018
I sprayed right off the line. 1st-3rd. You're going to need some traction though if you plan to spray in 1st.
I ran the stock fuel pump. I ran e85 for a little while. Most of the time I ran c16. Once in awhile vp110. I would have ran e85 more, but my fuel pump would have never kept up when I started running bigger shots.
#5
Word. I'm running e85 now. I have a 340lph and a hot wire kit so it (hopefully) should keep up with a 100-150 shot. My setup is pretty basic right now, 2.8, ported heads, polished gen v, overkill sbc cam, headers, e85, built trans. So probably barely at 300whp. I was looking at a progressive controller to bring the shot in slow at full boost but they are pricey. The last car I ran a shot on was my ls1 240sx and that was only from rolls
#6
10-17-2018
I don't spray nitrous but I do spray water/methanol and the controller is progressive, probably worth the extra money to get a progressive controller. it's based on boost, I have mine set to start at 10 psi and max at 12 psi
#7
Methanol injection controllers are a little different from nitrous controllers
#8
10-17-2018
I was wondering about that
#9
GXP Level Member
10-17-2018
If you're not going to run slicks, you probably shouldn't spray until you hit 2nd gear. I'd save money on a progressive controller in that way.
You should have enough pump for at least 100 shot with that 340 I would think.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#10
I plan on monitoring fuel pressure but the same type of pump handled over 450hp on my GN so it should handle my gs with a 100 shot no problem
#11
GXP Level Member
10-17-2018
